[mapserver-dev] Automated publication of MapServer code coverage
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Mon Jul 8 13:10:35 PDT 2013
Agreed, very interesting and useful output!
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
Sent: Monday, July 08, 2013 12:51 PM
To: Even Rouault
Cc: MapServer Dev Mailing List
Subject: Re: [mapserver-dev] Automated publication of MapServer code coverage
Even,
This is way cool !
Maybe the resulting pages could be uploaded to the mapserver.org website. I'm not sure about ftp access, but the upload could probably be done with an ssh key. I would also need that functionality to upload artifacts for failed test runs, in order to visually see which tests failed, but that's another story...
regards,
Thomas
On 6 July 2013 23:52, Even Rouault <even.rouault at mines-paris.org> wrote:
> Hi devs,
> What is it about ?
> I've setup a cronjob that publishes the code coverage of MapServer
> when running the msautotest suite.
> The results are published at the below links, and updated at each
> pushed commit in master :
> http://even.rouault.free.fr/mapserver_coverage_html/home/travis/build/
> rouault/mapserver/
> What for ?
> This can help improving msautotest to add better coverage for still
> untested code.
> How does it work ?
> I've setup a branch 'mapserver_coverage' in my mapserver fork :
> https://github.com/rouault/mapserver/commits/master_with_coverage
> This branch modifies the base .travis.yml to compile mapserver with
> coverage information (gcc --coverage flag), runs the testsuite and
> then generate the HTML report of code coverage afterwards with the
> lcov & genhtml utilities. At the end, it transfers the generated HTML files onto the above site via FTP.
> (There's a trick to be able to incrementally upload files between
> jobs. See run_code_coverage_upload.sh and find_updated_files.py )
> The changes of master_with_coverage vs master are summarized here :
> https://github.com/rouault/mapserver/compare/master_with_coverage
> The cronjob just merges 'master' into 'master_with_coverage' regularly
> and pushes the branch to github, which causes a Travis build.
> Why in a personnal branch ?
> The issue is with the FTP transfer onto my HTTP page. This requires of
> course specifying a password that is better kept private... Travis
> offers a way of doing this securely by putting an encrypted
> environment variable into the .travis.yml file. When Travis runs the
> script, it decrypts the environment variable. The variable is
> encoded/decoded with information linked to the Travis (or github ??
> I'm not sure) account. There's a security in Travis that prevents
> people running forks of the repository (or pull requests triggering
> Travis builds) to steal the decoded information. See
> http://about.travis- ci.org/docs/user/build-configuration/#Secure-environment-variables for more details.
> This could likely be merged into the official MapServer repository
> (this would avoid relying on the cronjob on my PC) if the project
> manages a FTP repository. I've not investigated if there would be more
> efficient/simple ways to upload files.
> Best regards,
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
