[mapserver-dev] RFC99: Remove GD support in 7.0
thomas bonfort
thomas.bonfort at gmail.com
Fri Jun 7 08:19:42 PDT 2013
Havard,
For area fills, Tamas has added a BITMAP type pattern in 6.4 that adresses
the issue. While it is not scalable, you can however change the color.
regards,
thomas
On 7 June 2013 17:11, Havard Tveite <havard.tveite at umb.no> wrote:
> I agree that it would be very good to get rid of GD.
> The only problem I see is that it is not possible to turn
> off anti-aliasing. That causes thin lines to appear in some
> cases when using vector symbols for area fills.
> Håvard
> On 6/7/2013 3:27 PM, thomas bonfort wrote:
>> Devs and Users,
>> Please have a look at RFC99 (http://mapserver.org/**
>> development/rfc/ms-rfc-99.html<http://mapserver.org/development/rfc/ms-rfc-99.html>
>> **). I am particularly interested in use-cases that would not be
>> supported if GD were to be removed.
>> cheers,
>> Thomas
>> ______________________________**_________________
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130607/80502320/attachment.html>
