[mapserver-dev] ERROR WORKING WITH MAPSERVER
reactorh
jgranadosp at gmail.com
Sat Mar 2 09:25:57 PST 2013
Stephen Woodbridge wrote
> On 3/2/2013 11:17 AM, reactorh wrote:
>> Any one could give me a hand on this.....
>> Thx
> So you got:
> > I compilded Mapserver and when i try to used it i got this:
> > PHP Warning: PHP Startup: Unable to load dynamic library
> '/usr/local/lib/php/extensions/no-debug-non-zts-20090626/php_mapscript.so'
> > libmapserver-6.2.0.so: cannot open shared object file: No such file or
> > directory in Unknown on line 0
> and ldd says this is the file it is looking for:
> /usr/local/lib/libmapserver-6.2.0.so
> So does this file exist?
> ls -l /usr/local/lib/libmapserver-6.2.0.so
> It need permission so that PHP can access it. It should be owned by root.
> So on my system I have stuff like:
> -rwxr-xr-x 1 root root 5942968 2012-07-02 09:36 libmapserver-6.1-dev.so
> -rwxr-xr-x 1 root root 5934502 2012-07-14 17:10
> libmapserver-6.2.0-beta1.so
> -rwxr-xr-x 1 root root 5933786 2012-08-01 10:40
> libmapserver-6.2.0-beta2.so
> -rwxr-xr-x 1 root root 5947268 2012-11-12 10:14 libmapserver-6.3-dev.so
> -rwxr-xr-x 1 root root 2066 2012-11-12 10:14 libmapserver.la
> lrwxrwxrwx 1 root root 23 2012-11-12 10:14 libmapserver.so ->
> Notice that libmapserver.so is a symlink that points to another file. If
> you have a symlink make sure you have the file it needs to point to also.
> If you are not sure about this stuff and nobody else is using mapserver
> on this box, you could clean it up by doing:
> # remove all the mapserver libraries
> sudo rm /usr/local/lib/libmapserver*
> cd /path/to/mapserver/src
> sudo make install
> # and for good measure
> sudo ldconfig
> then try your test again.
> -Steve
> -Steve
> mapserver-dev mailing list
> mapserver-dev at .osgeo
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Steve, thank you.......
I think it work....cause wheni ran php info
i got this..........
MapScript
MapServer Version MapServer version 6.2.0 OUTPUT=PNG OUTPUT=JPEG
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
PHP MapScript Version ($Revision$ $Date$)
Thanks great help
View this message in context: http://osgeo-org.1560.n6.nabble.com/ERROR-WORKING-WITH-MAPSERVER-tp5037405p5037994.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
