[mapserver-dev] Layer names in OGR connection strings (undocumented feature causing problems)
Tamas Szekeres
szekerest at gmail.com
Mon Mar 4 13:20:41 PST 2013
Brent,
Could you point me to the documentation where this syntax is mentioned? Is
this specific to OGR tile indexes?
Best regards,
Tamas
2013/3/3 Brent Fraser <bfraser at geoanalytic.com>
> Tamas,
> if I understand correctly you are talking about connection strings like:
> CONNECTIONTYPE OGR
> TILEINEX "PG:dbname='PN2010_0911' host='thinkcentre1' port='5432'
> user='PN2010_0911' password='PN2010_0911',images"
> note the comma and table name at the end.
> See http://lists.osgeo.org/pipermail/mapserver-dev/2011-April/011194.html
> Best Regards,
> Brent Fraser
> On 3/3/2013 2:09 PM, Tamas Szekeres wrote:
> Hi,
> According to a commit (made 11 years ago) in rev1370<http://trac.osgeo.org/mapserver/changeset/1370>
> the OGR connections strings are being split by the comma separators, see
> the following fragment in msOGRFileOpen:
> papszTokens = CSLTokenizeStringComplex( conn_decrypted, ",", TRUE,
> FALSE );
> if( CSLCount(papszTokens) > 0 )
> pszDSName = CPLStrdup( papszTokens[0] );
> if( CSLCount(papszTokens) > 1 )
> pszLayerDef = CPLStrdup( papszTokens[1] );
> This behaviour causes issues if the syntax of the connection string may
> normally expect commas, like with the issue:
> http://trac.osgeo.org/gdal/ticket/4885
> Does it make sense to split the connection strings this way?
> According to the OGR driver documentation<http://mapserver.org/en/input/vector/ogr.html>the layer definitions should go to the DATA section and not to the
> CONNECTION section.
> I'd be in favour of removing this fragment from the code but I'm not
> sure about all consequences.
> Best regards,
> Tamas
> mapserver-dev mailing listmapserver-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130304/b048f42a/attachment.html>
