[mapserver-dev] GetFeatureInfo problems
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Mar 5 05:18:54 PST 2013
Regarding the templating, I don't think that's a bug. When nothing is matched no templates are rendered. Instead an error is thrown and the normal error handling mechanisms (using ERROR and optionally in this case EMPTY) are used. May not be ideal but that's how it works.
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] on behalf of Fabian Schindler [fabian.schindler at eox.at]
Sent: Tuesday, March 05, 2013 4:13 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] GetFeatureInfo problems
Dear devs,
I just stumbled over what I think is a bug in both the templating
mechanism aswell as the msIO system (or the Python mapscript interface
to it). I added a minimal map, template and script in the attachment.
Basically what I do is the following:
- Dynamically create a map with one layer
- Set up an html template
- Add a shape (feature) to the layer
- Dispatch a WMS 1.3 GetFeatureInfo request
When the request "hits" the feature, all is well and I get a correct
template response. On the other hand, when I "miss" the feature no
templates are rendered, even the header and footer are left out; which I
consider the first bug.
The second problem is when I try to retrieve the bytes from the
installed stdout buffer (+content type):
msIO_stripStdoutBufferContentType: General error message. Corrupt
Content-Type header.
If I use `msIO_getStdoutBufferBytes()` instead, I get the following:
'Content-Type: text/html\r\n\r\n' so it seems that the header is
correct, but the response content is simply missing.
I get correct (still empty) responses when I use other response formats
like GML or text/plain.
Is there a possibility to get the correct content-type / response from
such degenerated messages?
Regards
Fabian
