[mapserver-dev] Request for review/comments on RFC 85 (Contour Layer Rendering)
Brent Fraser
bfraser at geoanalytic.com
Tue Mar 26 11:20:36 PDT 2013
Daniel (and Alan),
Sounds good; I know it can be a challenge to balance designing for
the future and just getting things built.
Something for future consideration: contour labeling - blanking/clipping
contour lines (but not other features) under the bound box of the
contour labels.
Thanks for all your work!
Best Regards,
Brent Fraser
On 3/26/2013 11:46 AM, Daniel Morissette wrote:
> Hi Brent,
> We discussed this important question here with the rest of the team
> and came to the conclusion that the current approach (CONNECTIONTYPE
> CONTOUR + CONNECTION pointing to raster data file) could be extended
> some day to support a reference to another layer of type RASTER as the
> CONNECTION source (similar to the way a TILEINDEX can refer to a
> separate layer as the tileindex source). Doing this would provide more
> flexibility but would also require lots of work under the hood so that
> is not likely to happen soon, but at least we know that we have a
> future solution to this problem that would be consistent with the
> current approach in the layer definition.
> And for the short term, if one has multiple DEM files to use as input
> then they could be indexed using a GDAL VRT. Providing a GDAL VRT as
> CONNECTION input to a contour layer is already supported by the
> current implementation.
> Hopefully my explanation makes sense
> Daniel
> On 13-03-26 10:33 AM, Brent Fraser wrote:
>> Steve,
>> I'd rather not overload (pollute? erode? highjack?) the meaning of
>> existing object keywords. For example, "TYPE CONTOUR" would imply
>> contours could only be rendered as lines; the future we might want to
>> render them as polygons.
>> While not ideal, using the PROCESSING directive to specify the type
>> of processing doesn't step on the other keywords.
>> Best Regards,
>> Brent Fraser
>> On 3/26/2013 8:10 AM, Lime, Steve D (MNIT) wrote:
>>> It would be nice to avoid using the processing directive in this way.
>>> Why not simply use the layer TYPE or "TYPE CONTOUR".
>>> Steve
>>> ________________________________________
>>> From: mapserver-dev-bounces at lists.osgeo.org
>>> [mapserver-dev-bounces at lists.osgeo.org] on behalf of Brent Fraser
>>> [bfraser at geoanalytic.com]
>>> Sent: Tuesday, March 26, 2013 8:47 AM
>>> To: Alan Boudreault
>>> Cc: mapserver-dev at lists.osgeo.org
>>> Subject: Re: [mapserver-dev] Request for review/comments on RFC 85
>>> Instead of
>>> CONNECTIONTYPE CONTOUR
>>> how about using
>>> PROCESSING "TYPE=CONTOUR"
>>> or
>>> PROCESSING "TYPE=DEM2CONTOUR"
>>> to allow the CONNECTIONTYPE to specify a connection to a database, etc
>>> Best Regards,
>>> Brent Fraser
>>> On 3/26/2013 6:21 AM, Alan Boudreault wrote:
>>>> Brent, yes, that's what I mean in my first point.. but typo. * the
>>>> connectiontype use will be kept*... until we define another way for
>>>> hybrid layers.
>>>> Thanks
>>>> Alan
>>>> On 13-03-25 10:07 PM, Brent Fraser wrote:
>>>>> So we're sticking with the "CONNECTIONTYPE CONTOUR"?
>>>>> Best Regards,
>>>>> Brent Fraser
>>>>> On 3/25/2013 1:22 PM, Alan Boudreault wrote:
>>>>>> Dev,
>>>>>> I would like to do the inclusion this week. A few comments about the
>>>>>> current implementation:
>>>>>> - For now, I think the contourlayer use will be kept, we will
>>>>>> need to
>>>>>> think more about hybrid layers for mapserver 6.4.
>>>>>> - Tileindex are not supported (yet)
>>>>>> - Postgis raster are not supported (yet)
>>>>>> http://mapserver.org/trunk/development/rfc/ms-rfc-85.html
>>>>>> I'll do the call for vote tomorrow morning if there's no objection.
>>>>>> Alan
>>>>>> On 12-09-21 03:22 AM, Havard Tveite wrote:
>>>>>>> I am not sure if contour generation should be a job for Mapserver,
>>>>>>> but if we decide to implement it, I think there is a need for
>>>>>>> processing directives for "smoothing" / generalisation.
>>>>>>> It should be possible to specify the level of "smoothing" for the
>>>>>>> DEM as well as for the resulting contours.
>>>>>>> Smoothing levels could be specified as the maximum deviation
>>>>>>> allowed from the "original".
>>>>>>> Contour "smoothing" / generalisation needs to pay attention to
>>>>>>> neighbouring contours / topology, so that contours don't cross
>>>>>>> after smoothing.
>>>>>>> Possible processing directives for a DEM tolerance of 25 units
>>>>>>> (xyz) and contour tolerance of 10 units (xy):
>>>>>>> PROCESSING "DEM_TOLERANCE"=25"
>>>>>>> PROCESSING "CONTOUR_TOLERANCE=10"
>>>>>>> They could be made scale dependent in the way that is suggested
>>>>>>> in the RFC.
>>>>>>> "TOLERANCE" might not be the best word - "GENERALIZATION"
>>>>>>> is also be a possibility.
>>>>>>> It would also be good to choose an approach that will not
>>>>>>> make it impossible to use a point layer (xyz or xy+height
>>>>>>> attribute) as a data source.
>>>>>>> Håvard
>>>>>>> On 9/20/2012 5:40 PM, Alan Boudreault wrote:
>>>>>>>> Hi devs,
>>>>>>>> I'd like to request some review on a pending RFC regarding support
>>>>>>>> for
>>>>>>>> contour layer rendering.
>>>>>>>> Please see
>>>>>>>> https://raw.github.com/mapserver/docs/master/en/development/rfc/ms-rfc-85.txt
>>>>>>>> The official rfc page should be updated in about a hour.
>>>>>>>> http://mapserver.org/trunk/development/rfc/ms-rfc-85.html.
>>>>>>>> Thanks,
>>>>>>>> Alan
>>>>>>> _______________________________________________
>>>>>>> mapserver-dev mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
