[mapserver-dev] [UVRASTER] reprojected layers
Yves Jacolin
yves.jacolin at camptocamp.com
Wed Mar 27 06:10:34 PDT 2013
Alan,
Thanks for your reply. We did some tests here and here some information:
* with a working UV raster layer in WMS:
we changed WIDTH/HEIGHT ratio in regards with BBOX ratio and uvraster layer
doesn't changed anymore.
* reprojection:
We had EPSG:3857 code and send a request to the WMS server for the uvraster
layer. We can't dispaly any feature, either using arrow or point. MapServer
log (DEBUG) 5 shows some informations on feature which seems correct to me
(raster cells are correctly reprojected in 3857).
As soon as we are using UVRASTER connectiontype, feature disappear. Indeed we
did several test and one of them was just display netcddf files. We are
currently using a tileindex with WMS-T and we wanted to be sure that there is
no other issue.
Hope I am clear, I am available in IRC if needed. About your question: any
test case you could run, I don't know, did you test EPSG:3857? Did you see the
same issue from us in regards with ratio changes?
One more information which can be important: MapServer version 6.1-dev [...] I
don't know when we built it ...
Y.
Le lundi 25 mars 2013 15:19:53 Alan Boudreault a écrit :
> Yves,
> Yes, I remember that the reprojection was working with UVRASTER. Any
> test case I could run?
> Alan
> On 13-03-25 12:29 PM, Yves Jacolin wrote:
> > Hello,
> > Is it possible to reproject an "UVRaster" layer (ie vector field) from
> > 4326 to 3857?
> > "DEBUG 5" mode shows me that raster cells are correctly reprojected to
> > 3857
> > but I can't even display it with a simple circle symbol (ie without using
> > UV_ANGLE or UV_LENGTH).
> > Thanks,
> > Y.
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43 (new)
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
