[mapserver-dev] R: Re: Get Raster from url
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Thu May 16 05:05:08 PDT 2013
Yes, that is possible. Mapserver uses GDAL so anything that will work at
the command line with gdalinfo will work in the mapfile.
However, just because it does work doesn't mean you want to run it that
way. There may be performance issues depending on the raster size and the
network speed.
You can use /vsicurl/<http_path_to_raster in the mapfile.
Mike
On 5/16/13 12:09 AM, "francescoboccacci at libero.it"
<francescoboccacci at libero.it> wrote:
>Hi all,
>my doubt is about the possiblity to load a remote raster tif directly
>from map
>file using mapserver.
>Is it possible?
>Thanks
>Francesco
>>----Messaggio originale----
>>Da: Michael.Smith at erdc.dren.mil
>>Data: 15/05/2013 17.41
>>A: "Jeff McKenna"<jmckenna at gatewaygeomatics.com>,
>>"mapserver-dev at lists.osgeo.
>org"<mapserver-dev at lists.osgeo.org>
>>Ogg: Re: [mapserver-dev] Get Raster from url
>>You can also use the /vsicurl/URL_to_raster method to access. It may not
>>be very performant.
>>Mike
>>On 5/15/13 8:32 AM, "Jeff McKenna" <jmckenna at gatewaygeomatics.com> wrote:
>>>On 2013-05-14 9:21 AM, francescoboccacci at libero.it wrote:
>>>> Hi all,
>>>> i have a question about get tiff raster image from a remote
>>>>repository.
>>>> Is it possible to get rater not from local server but reomote server
>>>>as
>>>>below:
>>>> LOCAL
>>>> SHAPEPATH "/data/raster/"
>>>> LAYER
>>>> NAME "TestRaster"
>>>> STATUS ON
>>>> TYPE RASTER
>>>> DATA "raster.tif"
>>>> REMOTE
>>>> LAYER
>>>> NAME "TestRaster"
>>>> STATUS ON
>>>> TYPE RASTER
>>>> DATA "http://fakeraster.com/raster.tif"
>>>> Thanks
>>>> Francesco
>>>Hmm likely not exactly as you need, but, initially when reading your
>>>question I thought of the GDAL "mini-drivers: (pan the page down)
>>>http://www.gdal.org/frmt_wms.html In other words, wrap that raster in a
>>>web mapping service.
>>>-jeff
>>>Jeff McKenna
>>>MapServer Consulting and Training Services
>>>http://www.gatewaygeomatics.com/
>>>_______________________________________________
>>>mapserver-dev mailing list
>>>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
