[mapserver-dev] Questions regarding to the extent/scale calculations in MapServer
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Nov 27 07:27:40 PST 2013
Steve L,
If this would be "easy" to change internally would it make sense to
allow this to be configured in the mapfile. By default the behavior
would remain the same, but we would have an option in the map object like:
PIXELMODEL POINT|AREA
then it would be easy for people to use what they need?
Food for thought!
-Steve W
On 11/27/2013 10:15 AM, Lime, Steve D (MNIT) wrote:
> The model was based on how ERDAS represented pixels back when MapServer
> was first written. I was a satellite image processing guy at the time
> and that was the initial focus of the software. Early code used the
> ERDAS C toolkit which reinforced the model. Personally I think the
> center of a pixel model makes more sense.
> Changing would probably be **very** disruptive. Not so much within
> MapServer code since the areas of change are pretty isolated in a few
> macros and transformations in the OWS code. The change would affect
> every mapfile that sets or uses scale denominators. Plus, clients would
> need to be updated and need to be made version aware.
> Steve
> *From:*mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] *On Behalf Of *Tamas Szekeres
> *Sent:* Wednesday, November 27, 2013 8:54 AM
> *To:* mapserver-dev at lists.osgeo.org
> *Subject:* [mapserver-dev] Questions regarding to the extent/scale
> Hi All,
> We've already noticed MapServer use a "center of pixel" representation
> when doing the extent/scale calculations in the code, which may cause
> quite some confusion for the users (mostly from the mapscript side)
> regarding to the behaviour.
> The most typical issue I've encountered is the complain about "why
> mapserver modifies my accurate extent specified in setExtent and why
> MapServer calculates a different scale I can calculate?"
> The reason of why is in fact that we consider the area coverage of the
> image is larger than the area coverage of the map extent (half of the
> pixel size in each directions). But the users (and mostly everyone in
> the world except MapServer) considers that the area coverage of the
> image is the same as the area coverage of the map extent.
> Can someone explain why we do things this way and do we have the chance
> to get rid of it?
> We could also eliminate the unnecessary transformations done in the
> WMS/WCS interface where the extent of the BBOX is considered to be in -
> let's say - edge of pixel representation and not in center of pixel
> representation.
> Best regards,
> Tamas
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
