[mapserver-dev] XML validation script in msautotest
Even Rouault
even.rouault at mines-paris.org
Sat Oct 26 12:31:02 PDT 2013
I've added in master a msautotest/pymod/xmlvalidate.py script that can be used
to validate XML documents. It is tuned for XML documents using OGC schemas,
but can potentially work in other contexts.
To use it, as a preliminary step, you need to first download the OGC schemas
and rewrite the URLs so that everything is local to have very fast validation
( I did try the XML_CATALOG_FILES mechanism to avoid rewriting URLs but there
were some libxml2 warnings that confused lxml ):
cd msautotest/wxs
python ../pymod/xmlvalidate.py -download_ogc_schemas
Then you can do for example :
$ python ../pymod/xmlvalidate.py expected/sos_cap.xml
(no output so validates)
Or more interesting :
$ python ../pymod/xmlvalidate.py -schema expected/wfs_describe.xml
expected/wfs_get_feature.xml
Element '{http://mapserver.gis.umn.edu/mapserver}province', attribute 'fid':
'province.Nova Scotia' is not a valid value of the atomic type 'xs:ID'., line
34
Well in that case, it happens that our mapfile configuration is not correct as
we use an attribute that can generate invalid gml:id for features.
(The script has some tuning to discard the mime headers in .xml files, to make
it easier to use)
For now, I've added its use when XML POST requests are done in tests. This
only prints a warning message when XML validation fails
I've fixed one instance of invalid XML POST in wfs_filter.map (
https://github.com/mapserver/msautotest/commit/dc743322b5f2ede3ad208b3abb8de0f3996f9eb0
) but I can see many warnings in wcs_post.map. The main reason is the absence
of " xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wcs/2.0
http://schemas.opengis.net/wcs/2.0/wcsAll.xsd"", but even when adding it,
there are errors in some GetCoverage requests.
We could also imagine adding special syntax in .map to ask for the output of a
request to be validated.
# XML_VALIDATE the_xml.xml [ the_schema.xml ]
Have fun !
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
