[mapserver-dev] RFC 86: Call for vote
thomas bonfort thomas.bonfort at gmail.com
Sat Sep 28 04:19:17 PDT 2013
Passed with +1 from ThomasB, MikeS, TomK, DanielM, JeffM, SteveL,
SteveW and PerryN
On 13 December 2012 15:36, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Steve,
> On Thu, Dec 13, 2012 at 3:29 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Thomas,
>> This update helps a lot.
>> If a user uses a name like %table% and also has a run time parameter
>> table=blabla is there any interaction or potential issues.
> yes, the runtime sub will take precedence and there will be *no* scale
> dependant substitution after that (as the %table% part of the string will
> have been replaced by "blabla" )
> thomas
>> Thank you,
>>   -SteveW
>> On 12/13/2012 5:13 AM, thomas bonfort wrote:
>>> Steve, Daniel, Jeff,
>>> In
>>> https://github.com/mapserver/docs/commit/db54f7cfa603a545a3a9308ee434527f462d9f0d
>>> I have tried to address the issues you arose.
>>> HTH,
>>> Thomas
>>> On Wed, Dec 12, 2012 at 5:01 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>     +1 SteveW  but ...
>>>     I think the RFC needs some updating to address Jeff's issue for the
>>>     doc team. Also re-reading the RFC I noticed that it does not specify
>>>     if the the ranges need to be ordered or not and in the email thread
>>>     you mentioned the there has to be a zero item as you check for that.
>>>     So I think some additional detail, to help the doc team. This could
>>>     be added once the code is checked in based on the final
>>> implementation.
>>>     BTW, I think this is an excellent design given all the discussion we
>>>     had earlier on it and it will a very useful feature for users.
>>> Thanks!
>>>     On 12/12/2012 6:06 AM, thomas bonfort wrote:
>>>         Hi guys,
>>>         Please vote on RFC 86, scale dependent token replacements (
>>>         http://mapserver.org/__development/rfc/ms-rfc-86.html
>>>         <http://mapserver.org/development/rfc/ms-rfc-86.html> )
>>>         I'll start with my +1.
>>>         thanks,
>>>         thomas
>>>         _________________________________________________
>>>         mapserver-dev mailing list
>>>         mapserver-dev at lists.osgeo.org
>>> <mailto:mapserver-dev at lists.osgeo.org>
>>>         http://lists.osgeo.org/__mailman/listinfo/mapserver-dev
>>>         <http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>>>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
