[mapserver-dev] Postgis, WFS and 3D coordinates
thomas bonfort
thomas.bonfort at gmail.com
Fri Apr 4 05:27:59 PDT 2014
Unfortunately no, you forgot to read Paul's comments. The processing
key is a start, but the wkb parser needs to be extended to support 3d
geometries.
On 4 April 2014 14:25, Guillaume Sueur <no-reply at neogeo-online.net> wrote:
> Hi Thomas,
> Thanks for your concern.
> Do you mean I just have to use PROCESSING "FORCE2D=off" ?
> That's worth a pint of Guinness !
> Best regards
> Le 04/04/2014 14:21, thomas bonfort a écrit :
>> Guillaume,
>> You have a bit of background here:
>> https://github.com/mapserver/mapserver/pull/4803
>> On 4 April 2014 13:14, Guillaume Sueur <no-reply at neogeo-online.net> wrote:
>>> Hi list,
>>> Using WFS against a Postgis layer made me realize that all the requests
>>> to Postgis were made with the ST_Force2D function, which makes it
>>> impossible to retrieve 3D coordinates on the client side. Can the use of
>>> ST_Force2D be avoided in case uf WFS ?
>>> Best regards
>>> Guillaume SUEUR
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
