[mapserver-dev] Postgis, WFS and 3D coordinates
Even Rouault
even.rouault at mines-paris.org
Fri Apr 4 05:31:36 PDT 2014
Guillaume,
Basically same answer as in
http://lists.osgeo.org/pipermail/mapserver-users/2014-March/076134.html , so
"no", with the extra precision that after reviewing
https://github.com/mapserver/mapserver/blob/master/mapgml.c the GML output code
used by the WFS server would also need to be updated to output the Z component.
Nothing particularly difficult to implement IMHO. Just needs to be done.
Question for historical MapServer developers: why is USE_POINT_Z_M a
compile-time #define : for performance reasons ?
Even
> Hi list,
> Using WFS against a Postgis layer made me realize that all the requests
> to Postgis were made with the ST_Force2D function, which makes it
> impossible to retrieve 3D coordinates on the client side. Can the use of
> ST_Force2D be avoided in case uf WFS ?
> Best regards
> Guillaume SUEUR
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
