[mapserver-dev] [EXTERNAL] Rethinking our doc site build workflow (+vote)
Smith, Michael ERDC-RDE-CRREL-NH Michael.Smith at erdc.dren.mil
Fri Apr 4 15:04:26 PDT 2014
I'm +1 on this
Mike
On 4/4/14, 4:55 PM, "thomas bonfort" <thomas.bonfort at gmail.com> wrote:
>PSC,
>In light of the recent projectsvm downtime and the (increasing, given
>the new translations) load we are putting on that server while
>building our docs, I would like to propose that we transition our
>build process to use travis-ci for the compilation part.
>In clear, docs would be automatically built on travis-ci.org once a
>commit is pushed on the stable or master branch, and would then be
>scp'd/rsync'd to the public projectvm directory on success.
>Advantages:
>- no need to maintain build scripts on the projectsvm
>- the actual travis config files are simple and minimal:
>https://github.com/tbonfort/docs/commit/1d178ab6e6d0765adfbb0fea40404a6a18
>03a969
>(without the logic to publish to mapserver.org yet, though)
>Inconveniences:
>- we rely on an external service we have no control on. we can always
>switch back to the current solution if needed (no www.mapserver.org
>downtime, the docs would just not be in sync while we transitioned).
>- building the PDFs has a non-negligeable impact on build times and
>apt packages needed to be installed on the travis instances. They
>would therefore be disabled by default, but might be enabled on a
>case-by-case basis if the commit message contains a magic keyword.
>- it might seem we are loosing control as to what is published on the
>mapserver.org website (given the resulting website is automatically
>published). In practice this is more or less already the case with the
>automatic builds happening on the projectsvm.
>I've had confirmation from the travis team that we are not abusing
>their system by implementing this:
>Hey Thomas,
>Thanks for getting in touch and checking with us!
>We absolutely don't mind you using our service to build and push your
>documentation site, quite the opposite.
>We're always happy to see people adopt Travis CI in unexpected and new
>ways, so by all means, ship it!
>Cheers, Mathias
>Mathias Meyer
>Before investing more time on this, I will need a go from the PSC. I'm
>going to be offline next week and unable to respond, but will start
>the transition at my return if no -1s are casted.
>+1 Use Travis-ci platform to build and publish mapserver website
>best regards,
>thomas
>_______________________________________________
>mapserver-dev mailing list
>mapserver-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
