[mapserver-dev] mapcache build with Visual Studio
Tamas Szekeres
szekerest at gmail.com
Fri Aug 8 08:30:53 PDT 2014
Hi Jeff,
So that means it is accepted to submit fixes in this regard.
Tamas
Jeff McKenna <jmckenna at gatewaygeomatics.com> ezt írta (2014. augusztus 8.,
péntek):
> Hi Tamas,
> I fixed many of those C99 issues about a year ago, and I recently noticed
> also that there is more code in MapCache now with those same issues. I
> also reported another issue with MSVC here in January, but I haven't
> tackled it yet (timegm)...so I've been doing MS4W builds with older
> MapCache releases (1.2.0 i think) as those fixes I made allow it to build
> in MSVC.
> -jeff
> On 2014-08-08 10:38 AM, Tamas Szekeres wrote:
>> Hi,
>> I'm trying to build mapcache with Visual Studio, but since MSVC is not
>> (fully) C99 compliant, I wonder how do we compile mapcache, since it
>> contains a number of C99 features like inline declarations. Compiling
>> the code as C++ (/TP) results in other kind of problems like c++
>> keywords causing issues etc.
>> This problem is also related to the issue mentioned:
>> https://github.com/mapserver/mapcache/issues/75
>> May I hope that the MSVC is still supported, so this problem can be
>> fixed in the code?
>> Best regards,
>> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140808/1c811052/attachment.html>
