[mapserver-dev] Derive units from a layer projection... Possible?
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Thu Aug 14 09:50:57 PDT 2014
Do we have any code to derive a layer's unit based on it's projection? The units can be explicitly set but that's not often the case. I'm reworking the WFS dwithin/beyond code and need a reliable way to derive units to convert the user supplied distance to layer units. Maybe its enough just to use layer->units, and then defer to map->units if not set.
Steve
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140814/48a1095b/attachment.html>
