[mapserver-dev] FW: [mapserver-users] WMS request fails when spaces are encoded as plus symbol in query part of URL
thomas bonfort
thomas.bonfort at gmail.com
Wed Aug 20 09:53:56 PDT 2014
Shouldn't we encode as %20 instead of leaving it as a space?
On 20 August 2014 18:52, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
> Devs: Is this a change that we should make for 7.0? Seems reasonable but I’m
> not sure what the side effects might be.
> Steve
> From: Moen, Paul T. [mailto:pmoen at nd.gov]
> Sent: Wednesday, August 20, 2014 9:44 AM
> To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] WMS request fails when spaces are encoded as
> Steve,
> You are right about the outcome of 1 and 2. 1 encodes the % and 2 throws
> the following error.
> msBuildWMSLayerURLBase(): One of wms_onlineresource, wms_server_version,
> wms_name metadata is missing in layer USGS DRG 250k Topo Maps. Please
> either provide a valid CONNECTION URL, or provide those values in the
> layer's metadata.\n\n
> I found the function as you said and
> I removed the
> if (*i == ' ')
> *j = '+';
> else
> from the function then recompiled.
> char *msEncodeUrlExcept(const char *data, const char except)
> char *hex = "0123456789ABCDEF";
> const char *i;
> char *j, *code;
> int inc;
> unsigned char ch;
> for (inc=0, i=data; *i!='\0'; i++)
> if (msEncodeChar(*i))
> inc += 2;
> code = (char*)msSmallMalloc(strlen(data)+inc+1);
> for (j=code, i=data; *i!='\0'; i++, j++) {
> if ( except != '\0' && *i == except ) {
> *j = except;
> } else if (msEncodeChar(*i)) {
> ch = *i;
> *j++ = '%';
> *j++ = hex[ch/16];
> *j = hex[ch%16];
> } else
> *j = *i;
> *j = '\0';
> return code;
> Everything works again after a mapserver recompile, install and finally a
> restart of apache. Thanks so much for the path to the solution.
> Paul Moen
> pmoen at nd.gov
> 701-328-2434
> From: <Lime>, "Steve D (MNIT)" <Steve.Lime at state.mn.us>
> Date: Wednesday, August 20, 2014 at 12:41 AM
> To: Paul Moen <pmoen at nd.gov>, "mapserver-users at lists.osgeo.org"
> <mapserver-users at lists.osgeo.org>
> Subject: RE: [mapserver-users] WMS request fails when spaces are encoded as
> Hmmm... Nice backwards compatibility ESRI. The +'s seem to still be quite
> legal (http://tools.ietf.org/html/rfc3986 and other references) in the query
> string (but not the path). I don't have access to test and I'm guessing
> these ideas won't work but they might be worth a quick try:
> 1) Try encoding the wms_name in the metadata: "wms_name"
> "Topomap%20DRG%20250k"
> 2) Don't set the wms_name in the metadata but add it to the connection:
> CONNECTION
> "http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?LAYERS=Topomap%20DRG%20250k&"
> I'm betting MapServer will encode the %'s in 1 and throw an error in 2.
> Otherwise you could hack the MapServer source. Function is called
> msEncodeUrlExcept() in mapstring.c you can see the section to change
> starting at line 1138 in git master
> (https://github.com/mapserver/mapserver/blob/master/mapstring.c)
> Maybe it's worth making this change as part of 7.0?
> Steve
> ________________________________
> From: mapserver-users-bounces at lists.osgeo.org
> [mapserver-users-bounces at lists.osgeo.org] on behalf of Moen, Paul T.
> [pmoen at nd.gov]
> Sent: Tuesday, August 19, 2014 4:56 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] WMS request fails when spaces are encoded as plus
> Hi all,
> We are consuming WMS services hosted by ESRI ArcGIS Server 10.0. The server
> was upgraded to ArcGIS Server 10.2.2 and we no longer can access layer names
> with spaces.
> This is the server’s capabilities.
> http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?request=GetCapabilities&service=WMS
> This is the layer I am using.
> LAYER
> # DEBUG 5
> CONNECTIONTYPE WMS
> CONNECTION
> "http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?"
> METADATA
> "wms_name" "Topomap DRG 250k"
> "wms_format" "image/png"
> "wms_server_version" "1.1.1"
> "wms_srs" "EPSG:2266"
> END
> TYPE RASTER
> STATUS OFF
> NAME "USGS DRG 250k Topo Maps"
> END
> Mapserver encodes this request as follows. Notice that the layer name,
> which is ‘Topomap DRG 250k’, is encoded with the spaces becoming the ‘+’
> character.
> http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?LAYERS=Topomap+DRG+250k&REQUEST=map&WMTVER=1.0.0&SERVICE=WMS&FORMAT=image/png&STYLES=&HEIGHT=1146&SRS=EPSG:2266&WIDTH=1271&BBOX=1906240.15992838,596656.333359479,2119730.85012732,789150.692893686&TRANSPARENT=TRUE&EXCEPTIONS=INIMAGE
> This returns the error in an image that says “Parameter ‘layers’ contains
> unacceptable layer names.”
> When I replace the + in the layer name with %20, LAYERS=Topomap+DRG+250k
> become LAYERS=Topomap%20DRG%20250k and the request becomes the following.
> http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?LAYERS=Topomap%20DRG%20250k&REQUEST=map&WMTVER=1.0.0&SERVICE=WMS&FORMAT=image/png&STYLES=&HEIGHT=1146&SRS=EPSG:2266&WIDTH=1271&BBOX=1906240.15992838,596656.333359479,2119730.85012732,789150.692893686&TRANSPARENT=TRUE&EXCEPTIONS=INIMAGE
> That request works. Obviously, ESRI is no longer decoding + as a space and
> therefore does not recognize the layer name with spaces.
> Is there any way I can have mapserver encode all characters using
> percent-encoding, or at least encode spaces as %20 instead of a + character.
> Thanks,
> Paul Moen
> pmoen at nd.gov
> 701-328-2434
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
