[mapserver-dev] need help with outputformat=kml for wfs
zach cruise zachc1980 at gmail.com
Fri Dec 19 18:26:49 PST 2014
i got it. works with "DRIVER OGR/KML" (not "DRIVER KML").
On 12/19/14, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
> Ok, let's try this outside of WFS context. You should be able to do
> something like:
>   /cgi-bin/mapserv?map=...&mode=map&mapext=...&map.imagetype=kml
> Does that work?
> Steve
> -----Original Message-----
> From: zach cruise [mailto:zachc1980 at gmail.com]
> Sent: Friday, December 19, 2014 9:27 AM
> To: Lime, Steve D (MNIT)
> Cc: mapserver-users; mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] need help with outputformat=kml for wfs
> yes
> On 12/18/14, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us> wrote:
>> Can you get at the layer GML without the output layer parameter?
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of zach
>> cruise
>> Sent: Thursday, December 18, 2014 9:18 AM
>> To: mapserver-users
>> Cc: mapserver-dev at lists.osgeo.org
>> Subject: [mapserver-dev] need help with outputformat=kml for wfs
>> using-
>> * MapServer version 6.4.0 ... OUTPUT=KML ... SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT ...
>> * httpd file-
>> 	<IfModule mime_module>
>> 		AddType application/vnd.google-earth.kml+xml .kml
>> 	</IfModule>
>> * map file-
>> 	MAP
>> 		IMAGETYPE kml
>> 		WEB
>> 			METADATA
>> 				"wfs_getfeature_formatlist" "kml"
>> 			END
>> 		END
>> 		OUTPUTFORMAT
>> 			NAME "kml"
>> 			DRIVER KML
>> 			MIMETYPE "application/vnd.google-earth.kml.xml"
>> 			IMAGEMODE RGB
>> 			IMAGEMODE FEATURE
>> 			EXTENSION "kml"
>> 			FORMATOPTION "ATTACHMENT=doc.kml"
>> 		END
>> 		LAYER
>> 		END
>> 	END
>> * url-
>> ../cgi-bin/mapserv?SERVICE=wfs&REQUEST=getfeature&TYPENAME=shoppinglis
>> t&VERSION=1.0.0&OUTPUTFORMAT=kml
>> (with or without "MODE=map")
>> but all i get is (no placemarks for points?)- <?xml version="1.0"
>> encoding="UTF-8"?>  <kml xmlns="http://www.opengis.net/kml/2.2">
>>    <Document>
>>      <Style id="LayerFolder_check">
>>        <ListStyle>
>>          <listItemType>check</listItemType>
>>        </ListStyle>
>>      </Style>
>>      <Style id="LayerFolder_checkHideChildren">
>>        <ListStyle>
>>          <listItemType>checkHideChildren</listItemType>
>>        </ListStyle>
>>      </Style>
>>      <Style id="LayerFolder_checkOffOnly">
>>        <ListStyle>
>>          <listItemType>checkOffOnly</listItemType>
>>        </ListStyle>
>>      </Style>
>>      <Style id="LayerFolder_radioFolder">
>>        <ListStyle>
>>          <listItemType>radioFolder</listItemType>
>>        </ListStyle>
>>      </Style>
>>      <name>shoppingmap</name>
>>      <Folder>
>>        <name>shoppinglist</name>
>>        <visibility>1</visibility>
>>        <styleUrl>#LayerFolder_check</styleUrl>
>>      </Folder>
>>    </Document>
>>  </kml>
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
