[mapserver-dev] managing of SVG format in applytSLD
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Tue Feb 4 06:20:48 PST 2014
It would make sense to me to limit references to local file system (for images too), however that kind of defeats the purpose of externally defined styling. The SLD spec does allow it I take it? Limiting references is different question than just adding SVG unless malicious SVG is inherently more risky than a PNG for some reason. Perhaps with certain output types (e.g. SVG, PDF) it's a bigger deal if the SVG passes through MapServer and isn't rasterized. Thoughts? With a better understanding here I'd be +1 for both 6.4 and master.
Maybe local vs. remote should be tunable somehow, e.g. OWS_ALLOW_REMOTE_SLD_ASSETS, false by default.
Steve
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] on behalf of thomas bonfort [thomas.bonfort at gmail.com]
Sent: Tuesday, February 04, 2014 4:06 AM
To: Tamas Szekeres
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] managing of SVG format in applytSLD
+1 for master
-0 for 6.4
On 4 February 2014 11:05, Tamas Szekeres <szekerest at gmail.com> wrote:
> Any objections to merge
> https://github.com/mapserver/mapserver/pull/4842
> at least to the master branch?
> That seems to be of primary importance for the authors/users.
> Tamas
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
