[mapserver-dev] Mapserver Projection Issue
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jan 1 08:47:38 PST 2014
Hi All,
I'm trying to run down a mapserver projection issue that is starting to
look like it might be the version of proj4. Sorry for the cross posting.
Situation:
I'm upgrading my server from Debian Lenny to Ubuntu 12.04 LTS and world
maps on the Ubuntu system projected to Spherical Mercator are messed up
and worked fine on Debian. I get the same issue using mapserver 6.2.1 or
5.6.8 and the big difference other than the OS and packages is that
Ubuntu is using proj4-4.8.0 and the older Debian system is using proj4-4.6.0
Is this a known issue? I can make the data mapfile available if that helps.
System details below.
Any help would be appreciated.
Thanks,
-Steve
Ubuntu system:
http://imaptools.com:8080/cgi-bin/mapserv?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
/u/www/cgi-bin/mapserv -v
MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
libproj-dev/precise uptodate 4.8.0-3~precise2
libproj0/precise uptodate 4.8.0-3~precise2
proj-bin/precise uptodate 4.8.0-3~precise2
proj-data/precise uptodate 4.8.0-3~precise2
# Spherical Mercator projection
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null +no_defs <>
cgi-mapserver/precise uptodate 6.2.1-2~precise3
libmapserver/precise uptodate 6.2.1-2~precise3
mapserver-bin/precise uptodate 6.2.1-2~precise3
Linux mappy 3.8.0-33-generic #48~precise1-Ubuntu SMP Thu Oct 24 16:28:06
UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
I also get the same result from:
/u/www/cgi-bin/mapserv-56 -v
MapServer version 5.6.8 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
which was built from source also using the libproj packages above.
Debian Lenny system:
http://gis.imaptools.com/cgi-bin/mapserv-6.2?MAP=%2Fu%2Fdata%2Fworld%2Fworld.map&FORMAT=image%2Fpng&LAYERS=World_WMS&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-27395030.9325,-21524667.16125,27395030.9325,21524667.16125&WIDTH=700&HEIGHT=550
proj/lenny uptodate 4.6.0-2
# Spherical Mercator - Google
Linux gis.leaddog.com 2.6.32-042stab081.8 #1 SMP Wed Oct 23 16:32:28 MSK
2013 x86_64 GNU/Linux
I built mapserver from source and I also get the same result from
mapserver-5.6.8 built from source.
