[mapserver-dev] Error building Mapserver 6.4.1 with fribidi
samuelmesa at gmail.com
Fri Jan 24 09:40:52 PST 2014
Thomas, the glib.h header exists in /usr/include/glib-2.0/glib.h. However, I do
not see the way to include the path in the CMake, since there is no variable
as GLIB_INCLUDE_DIR.
I have disabled this option in Archlinux package, however I'd like other
users to achieve set it, if they needed Fribidi.
Thank you
Samuel.
2014/1/24 Thomas Bonfort <thomas.bonfort at gmail.com>
> is the glib.h header available on your system ?
> On 23/01/2014 19:02, samuelmesa at gmail.com wrote:
> > Hi all, I'm trying to update the package Mapserver version 6.4.1 [1] for
> > Archlinux, however reports the following error during compilation:
> > "/usr/include/fribidi/fribidi-common.h: 61:20: fatal error: glib.h: No
> such
> > file or directory
> > # Include <glib.h>"
> > The PKGBUILD file is [2] and is fribidi version is 0.19.6 and glib2
> version
> > is 2.38.2.
> > How I can fix this compilation error?
> > Regards,
> > Samuel Mesa
> > [1] https://aur.archlinux.org/packages/mapserver
> > [2] https://aur.archlinux.org/packages/ma/mapserver/PKGBUILD
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
/ v \
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140124/5efd98a0/attachment.html>
