[mapserver-dev] msProjectRect may enter to infinite loop
Daniel Morissette dmorissette at mapgears.com
Wed Jul 23 05:30:26 PDT 2014
Seems fine to me at first sight.
Daniel
On 14-07-23 5:57 AM, Tamas Szekeres wrote:
> Got no answer, however I've prepared a fix.
> https://github.com/szekerest/mapserver/commit/54dda8c1adbc4a423d0f10706e6ee0502b1c04f4
> I'd prefer to fix this problem in the stable branch too.
> Let me know if anyone has objection to it.
> Tamas
> 2014-07-21 16:00 GMT+02:00 Tamas Szekeres <szekerest at gmail.com
> <mailto:szekerest at gmail.com>>:
>     Hi Devs,
>     Reprojecting a "very big" rectangle (for example zooming out too
>     far) may lead to infinite loop in msProjectSegment.
>     In my case the while loop in mapproject.c line 248-261 causes the
>     issue, where
>     midPoint.y=(subStart.y+subEnd.y)*0.5;
>     yields the same result as the initial subEnd.y and since the
>     projection is failing, the loop condition will never change.
>     What would be the reasonable solution for this issue?
>     May I think that returning immediately with an error if the loop
>     condition is not changing would be ok?
>     I would also think that bringing back the
>     former msProjectRectTraditionalEdge instead
>     of msProjectRectAsPolygon (in msProjectRect) would also be
>     reasonable in some conditions. msProjectRectAsPolygon may be very
>     inefficient regarding to the performance.
>     Best regards,
>     Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
T: +1 418-696-5056 #201
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
