[mapserver-dev] managing of SVG format in applytSLD
Gino Pirelli luipir at gmail.com
Mon Mar 3 06:34:29 PST 2014
I can see that importing SLD I've already a limitation getting external
graphics:
in the function: msSLDParseExternalGraphic(...)
mapogcsld.c:2079
ther is #if defined(USE_CURL)
USE_CURL is by default set to OFF, but I don't know how it is set in
destributed packages.
I think that, in case of parsing ExternalGraphics it's a too big
limitation jumping them assuming they are remote. They can be external
but locally defined.
I think that this control is redundant because it's is effectively set in:
mapsymbol.c: msAddImageSymbol(...)
please let me know what do you think about removing USE_CURL only in
mapogcsld.c:2079
Luigi Pirelli (luigi.pirelli at faunalia.it - luipir at gmail.com)
On 3 March 2014 12:22, Gino Pirelli <luipir at gmail.com> wrote:
> Hi, I'm the author of the Pull request.
> If' it's ok, I'll modify pull request avoiding remote sld using a
> compilation variable named OWS_ALLOW_REMOTE_SLD_ASSETS
> thank you
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140303/2e175683/attachment.html>
