[mapserver-dev] incorrect layer drawing order issue
Tamas Szekeres
szekerest at gmail.com
Sun Nov 9 13:21:56 PST 2014
Yes that would be the simplest approach in short term.
But I think it would also be reasonable to get it configurable for all
supported drivers, through mapfile and mapscript.
Best regards,
Tamas
2014-11-09 20:49 GMT+01:00 geographika <geographika at gmail.com>:
> Would a SORTBY clause be added as a keyword in the DATA statement?
> E.g. DATA "ogr_geometry from rivers USING UNIQUE ogr_fid USING SRID=4326
> USING SORTBY my_sort_fieldname"
> On 07/11/2014 12:49, Tamas Szekeres wrote:
> We could also extend the DATA section with a SORTBY clause for the mssql
> driver.
> Adding this feature to MSSQL (as per RFC 105) would anyway be fairly easy.
> Tamas
> 2014-11-07 11:24 GMT+01:00 geographika <geographika at gmail.com>:
>> Hi list,
>> I have come across an issue that is critical to the project I am working
>> on and wondered if it applies to all database drivers or just the SQL
>> Server 2008 one.
>> I have logged the issue on GitHub at:
>> https://github.com/mapserver/mapserver/issues/5008
>> I will try some tests over the weekend to see if the Postgres driver
>> works the same way, but there seems to be no way of guaranteeing feature
>> display order - even if all documentation suggests it can be achieved in a
>> database layer using "ORDER BY"
>> Whilst for a low number of records the order seems ordered, with 150+
>> features I get different images returned each time by my WMS service. No
>> use of clustered indexes, partition statements etc. can get around this as
>> SQL result sets can only be guaranteed with an ORDER BY in the outermost
>> statement.
>> I note that in http://mapserver.org/fr/development/rfc/ms-rfc-105.html
>> there is a new function msLayerBuildSQLOrderBy() that allows sorting to be
>> done outside of the layer's DATA statement for WFS requests with a SORTBY
>> parameter. Maybe this could also be used by a new LAYER "SORT" config
>> keyword?
>> I see the above is only implemented for a few drivers. The client would
>> be willing to fund adding this to the SQL Server driver if there are any
>> core devs interested in doing this.
>> Regards,
>> Seth
>> web: http://geographika.co.uk
>> twitter: @geographika
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20141109/eff0f0f7/attachment.html>
