[mapserver-dev] build problem
Belug
BELUG23 at GMAIL.COM
Thu Oct 9 03:44:35 PDT 2014
Hi, I have the same problem, but I need the SVG enable.
I'm using Ubuntu 14.04 on vagrant with those packages :
librsvg2-2:amd64 2.40.2-1
librsvg2-common:amd64 2.40.2-1
librsvg2-dev 2.40.2-1
libpango-1.0-0:amd64 1.36.3-1ubuntu1
libpangocairo-1.0-0:amd64 1.36.3-1ubuntu1
libpangoft2-1.0-0:amd64 1.36.3-1ubuntu1
Here's the two cmake I've tried :
The first :
cmake -DWITH_CLIENT_WMS=yes -DWITH_CLIENT_WFS=1 -DWITH_KML=1 -DWITH_SOS=1
-DWITH_PHP=1 -DWITH_PYTHON=1 -DWITH_THREAD_SAFETY=1 -DWITH_HARFBUZZ=1
-DWITH_FRIBIDI=1 -DWITH_FCGI=1 -DWITH_EXEMPI=1 -DCMAKE_BUILD_TYPE=Release
-DWITH_RSVG=1 -DWITH_CURL=1 -DWITH_CAIRO=1 -DWITH_PHP=1 -DWITH_PYTHON=1
and the same used in ubuntu-gis build minus java :
cmake -DCMAKE_EXE_LINKER_FLAGS="-Wl,-Bsymbolic-functions -Wl,-z,relro
-Wl,-z,now" -DCMAKE_MODULE_LINKER_FLAGS="-Wl,-Bsymbolic-functions
-Wl,-z,relro -Wl,-z,now"
-DCMAKE_SHARED_LINKER_FLAGS="-Wl,-Bsymbolic-functions -Wl,-z,relro
-Wl,-z,now" -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_VERBOSE_MAKEFILE=1
-DWITH_PROJ=1 -DWITH_KML=1 -DWITH_SOS=1 -DWITH_WMS=1 -DWITH_GD=1
-DWITH_FRIBIDI=1 -DWITH_ICONV=1 -DWITH_CAIRO=1 -DWITH_SVGCAIRO=0
-DWITH_RSVG=1 -DWITH_MYSQL=0 -DWITH_FCGI=1 -DWITH_GEOS=1 -DWITH_POSTGIS=1
-DWITH_GDAL=1 -DWITH_OGR=1 -DWITH_CURL=1 -DWITH_CLIENT_WMS=1
-DWITH_CLIENT_WFS=1 -DWITH_WFS=1 -DWITH_WCS=1 -DWITH_LIBXML2=1
-DWITH_THREAD_SAFETY=1 -DWITH_GIF=1 -DWITH_ORACLESPATIAL=0
-DWITH_ORACLE_PLUGIN=0 -DWITH_MSSQL2008=0 -DWITH_SDE_PLUGIN=0 -DWITH_SDE=0
-DWITH_EXEMPI=0 -DWITH_XMLMAPFILE=0 -DWITH_PYTHON=1 -DWITH_PHP=1
-DWITH_PERL=1 -DWITH_RUBY=0 -DWITH_JAVA=0 -DWITH_CSHARP=0
and I get this error message :
Linking C executable legend
/usr/bin/cmake -E cmake_link_script CMakeFiles/legend.dir/link.txt
--verbose=1
/usr/bin/cc -Wall -Wdeclaration-after-statement -Wl,-Bsymbolic-functions
-Wl,-z,relro -Wl,-z,now CMakeFiles/legend.dir/legend.c.o -o legend
-rdynamic libmapserver.so.6.5-dev -lpng -lz -ljpeg -lfreetype -lproj
-lfribidi /usr/local/lib/libharfbuzz.so -lcairo -lgeos_c -lpq -lgdal
-lrsvg-2 -lgobject-2.0 -lcurl -lxml2 -lpthread -lgif -ldl -lm
-Wl,-rpath,/vagrant/mapserver/build:/usr/local/lib:
//usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0: undefined reference to
`hb_glib_script_from_script'
`hb_glib_script_to_script'
`hb_glib_get_unicode_funcs'
collect2: error: ld returned 1 exit status
Same error on master or in branch-6-4
I to use vagrant ubuntu/trusty64
Thanks.
Peter Freimuth-4 wrote
> Hi Thomas,
> thanks for that hint. Disabling both SVG options and cleaning the folder
> actually resolved the build problem. I used the harfbuzz build settings
> from the Vagrantfile.
> Again, thanks for your support.
> Peter
> On Sep 29, 2014, at 10:32 AM, thomas bonfort <
> thomas.bonfort@
> <mailto:
> thomas.bonfort@
> >> wrote:
> Peter,
> - Completely unrelated, but the coverage flags are useless for an end
> user, they are going to slow your execution substantially. Start fresh
> from an empty build directory as cmake is going to have kept those flags
> in its cache. (cd build && rm -rf *)
> - How did you compile harfbuzz? try with ./configure --without-cairo
> --without-glib --without-icu
> - What happens if you disable RSVG support (I suspect that is the
> dependency that is pulling down pango)
> thomas
> On 28 September 2014 15:21, Peter Freimuth <
> peter.freimuth@
> <mailto:
> peter.freimuth@
> >> wrote:
> Hi mapserver devs,
> to verify that some of the bugfixes resolve two of the problems i
> currently have with map server i try to compile map server from scratch
> but whatever i tried i cannot resolve this problem:
> [ 90%] Building CXX object
> CMakeFiles/mapserver.dir/mapscript/v8/v8_mapscript.cpp.o
> Linking CXX shared library libmapserver.so
> [ 90%] Built target mapserver
> [ 91%] Building C object CMakeFiles/legend.dir/legend.c.o
> make[2]: *** [legend] Error 1
> make[1]: *** [CMakeFiles/legend.dir/all] Error 2
> make: *** [all] Error 2
> Seems that the headers or the lib of the but
> /usr/local/lib/libharfbuzz.so is available and i set
> -DCMAKE_PREFIX_PATH=/usr/local:/opt .
> i used
> cmake .. -DCMAKE_C_FLAGS="--coverage" -DCMAKE_CXX_FLAGS="--coverage"
> -DCMAKE_SHARED_LINKER_FLAGS="-lgcov" -DWITH_WCS=1 -DWITH_WFS=1
> -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_KML=1 -DWITH_SOS=1
> -DWITH_PHP=0 -DWITH_PYTHON=1 -DWITH_JAVA=0 -DWITH_THREAD_SAFETY=1
> -DWITH_RSVG=1 -DWITH_CURL=1 -DWITH_HARFBUZZ=1 -DWITH_POINT_Z_M=1
> -DWITH_XMLMAPFILE=1 -DWITH_GEOS=1 -DWITH_POSTGIS=1 -DWITH_LIBXML2=1
> -DWITH_OGR=1 -DWITH_GDAL=1 -DWITH_PROJ=1 -DWITH_GIF=1 -DWITH_GD=0
> -DFCGI_INCLUDE_DIR=/usr/include/fastcgi -DWITH_SVGCAIRO=0
> on a vagrant ubuntu/trusty64
> Mapserver was cloned from git master today.
> __________________________________
> mapserver-dev mailing list
> mapserver-dev at .osgeo
> <mailto:
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Peter Freimuth
> BlackBridge AG | Sitz Berlin | Amtsgericht Charlottenburg -
> Registergericht | HRB 152785 | Aufsichtsratsvorsitzender: David Westwood |
> Vorstand: Ryan Johnson
View this message in context: http://osgeo-org.1560.x6.nabble.com/build-problem-tp5164605p5166654.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
