[mapserver-dev] Disabling GML output for one layer
Even Rouault
even.rouault at spatialys.com
Sun Oct 19 08:51:00 PDT 2014
Angelos,
DUMP has no effect at all on anything since 6.0 as mentionned in
http://mapserver.org/mapfile/layer.html (although the phrasing is perhaps a bit
confusing as it reflects the previous behaviour)
According to http://mapserver.org/ogc/wms_server.html, you might want to set
the following metadata on the LAYER on which you want do disable
GetFeatureInfo :
"wms_enable_request" "* !GetFeatureInfo"
This will override the global WEB.METADATA "ows_enable_request" "*" that
allows everything.
Even
> Hi all,
> I am having trouble to disable GML output (for WMS GetFeatureInfo
> request) for one of my layers.
> 83.212.100.7/cgi-bin/mapserv?map=/home/data/WMS/wms.map&LAYERS=MODIS_GPP_La
> test,CLASSIFICATION&QUERY_LAYERS=MODIS_GPP_Latest,CLASSIFICATION&STYLES=,&S
> ERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&BBOX=2316381.337124%2C48458
> 49.841337%2C2351083.747961%2C4879902.537433&FEATURE_COUNT=10&HEIGHT=891&WID
> TH=908&FORMAT=image%2Fpng&INFO_FORMAT=application%2Fvnd.ogc.gml&SRS=EPSG%3A
> 900913&X=391&Y=309
> From the documentation it seems that DUMP OFF used to do that.
> How do I replicate this feature on latest versions?
> My layer definition:
> LAYER
> NAME MODIS_GPP_Latest
> PROJECTION
> "init=epsg:32634"
> END
> TYPE RASTER
> DUMP FALSE
> STATUS ON
> DATA ./latest_GPP.tif
> TEMPLATE ./template.html
> PROCESSING "SCALE=AUTO"
> OFFSITE 0 0 0
> METADATA
> "ows_title" "Gross Primary Production"
> "ows_abstract" "Latest Gross Primary Production"
> "ows_keywordlist" "NASA,MODIS"
> "wms_opaque" "0"
> "wms_metadataurl_format" "text/html"
> "wms_dataurl_format" "image/png"
> "ows_metadataurl_type" "FGDC"
> "ows_metadataurl_href" "http://modis.gsfc.nasa.gov/"
> "wms_dataurl_href" "ftp://e4ftl01.cr.usgs.gov"
> END
> END
> My MAP metadata:
> METADATA
> "ows_schemas_location" "http://schemas.opengis.net"
> "ows_title" "MapServer for PindosGIS Project"
> "ows_abstract" "Latest MODIS imagery through OGC Web Services"
> "ows_keywordlist" "MapServer,MODIS,NASA"
> "ows_onlineresource"
> "http://83.212.100.7/cgi-bin/mapserv?map=/home/data/WMS/wms.map"
> "ows_fees" "none"
> "ows_accessconstraints" "none"
> "ows_srs" "EPSG:32634 EPSG:4326 EPSG:900913 EPSG:3857 EPSG:102113
> EPSG:2100"
> "wms_feature_info_mime_type" "text/html"
> "wms_getmap_formatlist" "image/png,image/gif"
> END
> I have one vector layer and one raster layer and I want to disable the
> raster layer result.
> Unfortunately the layer cannot be removed from the request (I drill down
> WMS GetFeatureInfo on my GeoExt application)
> Thanks,
> Angelos
http://www.spatialys.com
