[mapserver-dev] Crash on Windows: fontcache.c
Even Rouault
even.rouault at spatialys.com
Sun Oct 19 12:30:41 PDT 2014
Le dimanche 19 octobre 2014 21:14:33, Jeff McKenna a écrit :
> Hi devs,
> With git/master on Windows, I trigger a crash of
> mapserv.exe/mapserver.dll any time I call mapserv.exe in CGI mode. (no
> issue with MapServer 6.4.1)
> - The good news is that I can reproduce this at the commandline with
> 'mapserv -nh'.
> C:\ms4w> mapserv -nh
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> For other options please try using the --help switch.
> (then a crash occurs, with this info below)
> Problem signature:
> Problem Event Name: APPCRASH
> Application Name: mapserv.exe
> Application Version: 0.0.0.0
> Application Timestamp: 54440643
> Fault Module Name: mapserver.dll
> Fault Module Version: 0.0.0.0
> Fault Module Timestamp: 54440640
> Exception Code: c0000005
> Exception Offset: 00274c8b
> OS Version: 6.0.6002.2.2.0.768.2
> - I compiled mapserv in Debug mode (Visual Studio 2008)
> - in the Visual Studio 2008 debugger this message appears:
> message: Unhandled exception at 0x10274c8b (mapserver.dll) in
> mapserv.exe:
> 0xC0000005: Access violation reading location 0xdddddddd.
> - the debugger stops at:
> fontcache.c
> line 92: FT_Done_FreeType(c->library);
> - the call stack at that point is:
> mapserver.dll!_FT_Done_Library() + 0x7b bytes
> mapserver.dll!_FT_Done_FreeType() + 0x11 bytes
> mapserver.dll!msFreeFontCache(ft_cache * c=0x104bf560) Line 92 + 0xb
> bytes
> mapserver.dll!msFontCacheCleanup() Line 164 + 0x9 bytes
> mapserver.dll!msCleanup(int signal=1) Line 1967
> mapserv.exe!msCleanupOnExit() Line 74 + 0x7 bytes
> msvcr90d.dll!doexit(int code=0, int quick=0, int retcaller=0) Line
> 591 C msvcr90d.dll!exit(int code=0) Line 412 + 0xd bytes
> mapserv.exe!main(int argc=2, char * * argv=0x0453da10) Line 315 +
> 0xa bytes
> mapserv.exe!__tmainCRTStartup() Line 586 + 0x19 bytes
> mapserv.exe!mainCRTStartup() Line 403
> kernel32.dll!75f3d3c9()
> [Frames below may be incorrect and/or missing, no symbols loaded
> for kernel32.dll]
> ntdll.dll!77871603()
> ntdll.dll!778715d6()
> libeay32.dll!cms_SignedData_init_bio(CMS_ContentInfo_st * cms=) Line
> 817 + 0xe bytes
> I'm wondering if anyone has any ideas of what I can try, or if you need
> more information. I am pretty stuck. Thanks everyone,
Jeff,
Not tested, but by code review, I believe the issue is that msCleanup() must
be called twice on Windows.
Once by msCleanup(0) at line 308 of mapserv.c
And twiche by the code at line 237 of mapserv.c
#ifdef WIN32
atexit( msCleanupOnExit );
#endif
I'd recommand you trying to remove those 3 lines. I can't see any reason for a
win32 specific code path.
Even
http://www.spatialys.com
