[mapserver-dev] Crash on Windows: fontcache.c
Even Rouault
even.rouault at spatialys.com
Sun Oct 19 14:27:03 PDT 2014
Le dimanche 19 octobre 2014 22:01:31, Even Rouault a écrit :
> > Even that did it! (I removed the second call, the 3 lines, for
> > msCleanupOnExit, as you said). Wow! Thank you so much. Will you
> > commit this into master now? I can also, but, you solved it.
> > I can also file a ticket if you want this to be recorded. Let me know.
> I could commit, but perhaps Thomas should confirm.
PR: https://github.com/mapserver/mapserver/pull/5018
http://www.spatialys.com
