[mapserver-dev] Unsupported Filter
Farwell, Michael D - Exelis
michael.farwell at exelisinc.com
Thu Oct 30 11:19:24 PDT 2014
Even,
GeoTools uses the following envelope for WFS 1.1:
<ogc:BBOX>
<ogc:PropertyName>msGeometry</ogc:PropertyName>
<gml:Envelope srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:lowerCorner>-59.0 -35.0</gml:lowerCorner>
<gml:upperCorner>-58.0 -34.0</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
Mike
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Thursday, October 30, 2014 2:06 PM
To: mapserver-dev at lists.osgeo.org
Cc: Farwell, Michael D - Exelis
Subject: Re: [mapserver-dev] Unsupported Filter
Le jeudi 30 octobre 2014 18:55:03, Farwell, Michael D - Exelis a écrit :
> Rahkonen,
> Thanks for an actual working query.
> Turns out it was the style of the coordinates.
> <gml:coord><gml:X>-59.0</gml:X><gml:Y>-35.0</gml:Y></gml:coord><gml:co
> ord>< gml:X>-58.0</gml:X><gml:Y>-34.0</gml:Y></gml:coord> Vs.
> <gml:coordinates cs="," decimal="." ts=" ">-59,-35
> -58,-34</gml:coordinates>
> Unfortunately, GeoTools formulates the request as X,Y. There may be a
> way to override this behavior.
Mike,
Digging a bit, I see that I added this test case during the development of WFS 2.0. I don't remember if I fixed something in that area, or if it was introduced before, but anyway this should be supported now with the 7.0dev version :
# Verify BBOX Result with <Box><coord><X> </X><Y> </Y></coord><coord><X> </X><Y> </Y></coord></Box> # RUN_PARMS: wfs_filter_bbox_old_fashion.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=popplace&FILTER=<Filter><BBOX><PropertyName>POINT</PropertyName><Box+srsName=%22urn:ogc:def:crs:EPSG:26920%22><coord><X>272868.16</X><Y>4938053.09</Y></coord><coord><X>281261.3</X><Y>4951109.39</Y></coord></Box></BBOX></Filter>"
> [RESULT]
Did you check if there was a way to make GeoTools use WFS 1.1 style BBOX ?
Should be better supported that this anciant way of expressing GML box.
Even
> Thanks for your help.
> Mike
> From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen at mmmtike.fi]
> Sent: Thursday, October 30, 2014 12:20 PM
> To: Farwell, Michael D - Exelis; 'Lime, Steve D (MNIT)';
> 'mapserver-dev at lists.osgeo.org' Subject: Re: Unsupported Filter
> Hi,
> I did not study why it does not work but here is a complete GetFeature
> POST with BBOX filter that works. Compare with yours and report what
> makes the difference.
> POST http://demo.mapserver.org/cgi-bin/wfs HTTP/1.1
> Content-Type: text/xml
> User-Agent: Jakarta Commons-HttpClient/3.0-beta1
> Host: demo.mapserver.org
> Proxy-Connection: Keep-Alive
> Content-Length: 835
> <wfs:GetFeature service="WFS" version="1.0.0"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd<http://www.opengis.
> net/ wfs%20http:/schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd>"
> maxFeatures="1000" outputFormat="GML2"><wfs:Query
> typeName="cities"><ogc:PropertyName>NAME</ogc:PropertyName><ogc:Proper
> tyNa
> me>POPULATION</ogc:PropertyName><ogc:PropertyName>msGeometry</ogc:Prop
> me>ertyN
> ame><ogc:Filter><ogc:BBOX><ogc:PropertyName>msGeometry</ogc:PropertyNa
> ame>me><g
> ml:Box xmlns:gml="http://www.opengis.net/gml"><gml:coordinates cs=","
> decimal="." ts=" ">-56.020765027322405,-4.650424681845783
> -36.836187006678806,25.4390713715847</gml:coordinates></gml:Box></ogc:
> BBOX
> ></ogc:Filter></wfs:Query></wfs:GetFeature>
> -Jukka Rahkonen-
> Lähettäjä:
> mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lis
> ts.o sgeo.org> [mailto:mapserver-dev-bounces at lists.osgeo.org] Puolesta
> Farwell, Michael D - Exelis Lähetetty: 30. lokakuuta 2014 17:42
> Vastaanottaja: Lime, Steve D (MNIT);
> mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org> Aihe:
> Steve,
> Thanks for the reply.
> I'm having the same issue with an internal 6.x mapserver, so I tried
> the demo server. Are you aware of other publicly available mapservers
> that could be used for minimal testing.
> Mike
> From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
> Sent: Thursday, October 30, 2014 11:38 AM
> Subject: RE: Unsupported Filter
> That's a 5.6.5 server. I wonder if newer versions have the same limitation.
> From:
> ts.o sgeo.org> [mailto:mapserver-dev-bounces at lists.osgeo.org] On
> Behalf Of Farwell, Michael D - Exelis Sent: Thursday, October 30, 2014
> 10:23 AM
> To:
> Subject: [mapserver-dev] Unsupported Filter
> Mapserver dev,
> Does anyone know why the UMN demo map server does not support the
> following WFS 1.0.0 post request?:
> curl -X POST
> 'http://demo.mapserver.org/cgi-bin/wfs?REQUEST=GetFeature&VERSION=1.0.
> 0&SE RVICE=WFS' -d @/tmp/post.xml -H 'Content-Type: application/xml'
> -k
> Where /tmp/post.xml contains:
> <?xml version="1.0" encoding="UTF-8"?><wfs:GetFeature
> xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> xmlns:gml="http://www.opengis.net/gml" handle="GeoTools
> 13-SNAPSHOT(f758d2e99d6008f6a27438946de5ef914960f605) WFS 1.0.0
> DataStore @localhost.localdomain#1" maxFeatures="10" outputFormat="GML2"
> service="WFS" version="1.0.0"> <wfs:Query typeName="ms:cities">
> <ogc:PropertyName>POPULATION</ogc:PropertyName>
> <ogc:Filter>
> <ogc:BBOX>
> <gml:Box srsName="urn:x-ogc:def:crs:EPSG:4326">
> <gml:coord>
> </gml:coord>
> <gml:coord>
> <gml:X>-58.0</gml:X>
> </gml:coord>
> </gml:Box>
> </ogc:BBOX>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> I'm getting the following message:
> WFSGetFeature(): WFS server error. Invalid or Unsupported FILTER in
> GetFeature
> Thanks,
> Mike
> ________________________________
> This e-mail and any files transmitted with it may be proprietary and
> are intended solely for the use of the individual or entity to whom
> they are addressed. If you have received this e-mail in error please
> notify the sender. Please note that any views or opinions presented in
> this e-mail are solely those of the author and do not necessarily
> represent those of Exelis Inc. The recipient should check this e-mail
> and any attachments for the presence of viruses. Exelis Inc. accepts
> no liability for any damage caused by any virus transmitted by this e-mail.
Spatialys - Geospatial professional services http://www.spatialys.com
