[mapserver-dev] [EXTERNAL] Re: Draft FOSS4G Project Status Presentation...
Schylberg Lars lars.schylberg at saabgroup.com
Mon Sep 15 01:23:02 PDT 2014
I did a presentation last week about my experiences from using the scribe-syntax at FOSS4G in Portland.
I have used the scribe syntax a little more than a year for two projects. It has really helped.
I really like scale management part and that you can have multiple DATA sources and style elements based on scale in the same layer.
That and the variables are the main advantages.
Lars Schylberg
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
Sent: den 9 september 2014 15:49
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] [EXTERNAL] Re: Draft FOSS4G Project Status Presentation...
On 14-09-08 4:39 PM, Rahkonen Jukka (Tike) wrote:
> Daniel Morissette wrote:
>> On 14-09-08 2:53 PM, Smith, Michael ERDC-RDE-CRREL-NH wrote:
>>> For post 7.0, we should discuss adding Scribe syntax support into
>>> MapServer.
>> Yep. Agreed.
> Hi,
> I suggest not to hide the discussion from Mapserver users. Scribe syntax feels interesting for me. I have wished variables for a long time even INCLUDES can partly serve the same purpose. And Scribe syntax seems to change ENDs into curly brackets which looks cool.
Sure, but to be really useful the discussion on mapserver-users should come with an intro to the syntax or perhaps even a draft RFC to serve as a base for discussion as most users don't know what Scribe is about.
Actually, there is a good intro at
http://scribeui.org/scribe-syntax.html so we could possibly use that to start a discussion. Do you want to start the discussion on the users list?
Daniel
Daniel Morissette
T: +1 418-696-5056 #201
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000 _______________________________________________
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
