[mapserver-dev] compiling question, Mr SID with gdal -> mapserver
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Aug 26 07:35:17 PDT 2015
Hello,
Documentation for building GDAL and its drivers live at:
https://trac.osgeo.org/gdal/wiki/BuildHints You can find MrSID listed
on that page, at https://trac.osgeo.org/gdal/wiki/MrSID
As you travel down this page, remember that those pages are wikis, and
you can help others by updating the page/steps that you use. And if you
need to create a new page please do. For example, if by bringing this
up on the GDAL-dev list they help you and you find out specific CentOS
steps, you could update that wiki so that others can follow your lessons
learned.
Thanks,
-jeff
On 2015-08-26 11:23 AM, Jukka Sirviö wrote:
> Hello,
> First of all, thank you for the great product! Keep up the good work.
> Have been using Mapserver for over a decade now. I figure that the users
> group would not have answers for compiling related questions, so mailing
> the question here?
> My question is that is there any decent advice / documentation / notes
> on compiling latest Mr SID SDK into gdal and to mapserver on CentOS? jp2
> images decoding seems to work best when using Mr SID SDK. I’m able to
> compile the sdk into gdal, but with mapserver compilation there is no
> luck anymore (autoconf seems to work ok). Compiling without Mr SID, the
> other “basic“ gdal & mapserver functionalities are working normally.
> Thanks in advance!
> *Jukka Sirviö*
> Lead Designer
> Water and Energy Management Systems
> MIPRO OY
> Kunnanmäki 9 | FI-50600 Mikkeli | Finland
> Tel. +358 15 200 1213 | Mobile +358 44 749 1213 | Fax +358 15 200 1333
> jukka.sirvio at mipro.fi <mailto:jukka.sirvio at mipro.fi>|
> http://www.mipro.fi <http://www.mipro.fi/>
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
