[mapserver-dev] pink screen after activating several layers (mapserver version 6.2.0)
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Dec 3 10:40:51 PST 2015
Try running this from the command line:
/path/to/cgi-bin/mapserv
QUERY_STRING='MAP=%2Fvar%2Fwww%2Fhtdocs%2Fwebsig%2Fv5%2Ftmp%2Ftmp%2F0olt4opvnq180qoiaukec1t6o2.map&TRANSPARENT=FALSE&LAYERS=[layergroup]&FORMAT=png&MAXEXTENT=29754.890054972%2C-218525.78697617%2C87631.601716573%2C-160649.07531457&GUTTER=0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27492&RANDOM=0.6198567883111537&BBOX=-36556.702679255,-245546.77592733,153943.1944508,-133628.08636341&WIDTH=1440&HEIGHT=846'
And see what kind of error you get.
-Steve W
On 12/3/2015 12:35 PM, Donald wrote:
> The number of layers of the mapfile is above 250.
> I get a error in the console of the browser when the pink screen shows.
> It's http://[myIP]/cgi-bin/mapserv?MAP=%2Fvar%2Fwww%2Fhtdocs%2Fwebsig%2Fv5%2Ftmp%2Ftmp%2F0olt4opvnq180qoiaukec1t6o2.map&TRANSPARENT=FALSE&LAYERS=[layergroup]&FORMAT=png&MAXEXTENT=29754.890054972%2C-218525.78697617%2C87631.601716573%2C-160649.07531457&GUTTER=0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27492&RANDOM=0.6198567883111537&BBOX=-36556.702679255,-245546.77592733,153943.1944508,-133628.08636341&WIDTH=1440&HEIGHT=846
> *(net::ERR_EMPTY_RESPONSE) *
> The mapfile generated by mapserv exists in the tmp folder and the
> structure of the file is right. The map file generated has chmod 777 as
> well as the folder. Any help would be appreciated.
> 2015-12-03 14:35 GMT+00:00 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>:
> Please reply to the list so everyone can benefit from the questions
> and answers and there are a lot of other people that might have
> input to the problem.
> On 12/3/2015 5:35 AM, Donald wrote:
> Hi Steve,
> I don't believe that it is a problem with open layers. I tested
> The point is to load the pink tile in a separate window so you can
> view the error message and see why it failed.
> individually one layer at a time and I could conclude that I got the
> pink screen when a certain amount of activated layers are reached
> regardless of the order. Do you know if mapserver has some
> configuration
> that restrict the number of layers to render or some
> configuration about
> memory limit to render the layers ?
> No, I do not think this is the case. How many layers are in your
> mapfile?
> -Steve W
> thanks
> 2015-12-02 16:28 GMT+00:00 Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
> <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>:
> On 12/2/2015 11:22 AM, Donald wrote:
> cheers,
> I have several layers that I can activate. When I
> activate all
> at once I get
> a pink screen. If I activate a layer individually by
> selecting
> one at a time
> I still get a pink screen even though some layers are
> correctly
> drawn. I
> checked the error log and I the last log line I have says
> "freeing map at
> 0xa022230". To see the map again I have to unselect all
> layers.
> Any thoughs on how to solve the problem ?
> Mostly likely it is only one of some of the layers that are
> having
> an issue. So trying, selecting one layer at a time to
> figure out
> which layer is causing the problem.
> Also a "pink screen" sounds like you are using OpenLayers
> and the
> pink is for a failure to render the image. In FireFox,
> right click
> on the pink image and select view image this image or copy
> the image
> url and paste it into a new tab/window and you might get an
> error
> message that would be helpful.
> -Steve W
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> <mailto:mapserver-dev at lists.osgeo.org>
> <mailto:mapserver-dev at lists.osgeo.org>>
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
