[mapserver-dev] pink screen after activating several layers (mapserver version 6.2.0)
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Dec 4 01:49:45 PST 2015
Apache has a max size of the request string set to 8190 by default but it can be configured to some other value. Perhaps you should check that.
http://httpd.apache.org/docs/2.0/mod/core.html#limitrequestline
-Jukka Rahkonen-
Donald wrote:
I've tried your query on the URL copied from the browser console when I enable all the layers wich is:
http://[my-ip]/cgi-bin/mapserv?MAP=%2Fvar%2Fwww%2Fhtdocs%2Fwebsig%2Fv5%2Ftmp%2Ftmp%2F0jtbdfs8dcivii2ugk0gmgf9g3.map&TRANSPARENT=FALSE&LAYERS=0cc6928e741d75e7a92396317522069e%2C11953163dd7fb12669b41a48f78a29b6%2Ca1ef52d000a69fe51471bfb2c5f33f2b%2C44f4d07f1c8299921e49ad583e6172ac%2C193aeff547d5ae031961a398f3d85103%2C436be651135fc8603fe1eebef755a414%2Ca189d1d6323604bf825894b367be53d8%2C56aac7f0dc0698c8fd1d78b5775cad8b%2C96291e7f00056d5fa2a29a7bb01a5c69%2C9c94ffae5dafd57bc0a5a9a74c33bda1%2Ce2cf648ae25fae6974151b3d8cfe1bd5%2Ca28656725f374cb3e71a201b531e80cd%2C8dc37d46aebc3afc7600e5ff3a98701e%2C8915c77907ad5fc844b6cac7fd4a36ca%2C7209f9f3fb9d9fe99ce4f89b9287fb53%2C35d0e2d968e9feccbca2e105770b7d1a%2C1ff33d2387634a2ba74bfd89e4fae299%2C499dd1b7fff1fe45c60c1e0327f31ac7%2C90542348786781a92dc3159edb3acaeb%2C8f1483fd43d37f2b201b6013cf560548%2Cc031bd271524cfaf3ca33d9a7cdd6963%2C3b51f0944a15a288a8f63a69184eefed%2Cbe0c65808c8b98930fd422c71f4eb503%2C214f89202b43814a91023650bcd7812e%2C466faab804ea25abe829be99d5e9bd62%2C67f56f1066f936643e650ab9abbe8782%2C98a38e6bc3df67b13c88f895b0475bda%2C1ceea623bcd09fd1c588eeab49348267%2C654d83ccc5d76820d377ca1ae5c1b1e7%2Cec66e23e08411ca94ac3140f8b092b32%2C7e87e2573bea6ca53812c110c8b3044f%2C86425ea19a3ef32b8e04bf17d99d7a46%2C6b8f11ea22cc3b3d21054af721405f74%2C1315d315bde3c15132bfe573c31f2e16%2C7504b254d644b0f91405e4fdddc19ae0%2C60cd83680a9c13ad66f64746a7017f5e%2C2bde0769323a37aaf488a8ea7925f80f%2C77404689d7440aaf8316d8ef916244cb%2C1bb0595cd85c6f555b1a421c714a70a2%2C55f5be4757a81d063e68ec307346ead8%2Cd9c9e5d87b555029cddd3ca66e016595%2C76534893b6a38e0b25f8140f1f580968%2Ce7e425d53704ee79df4fdd45e58bf4e6%2C61228e7887c83f5b85a0e781d5f3de2e%2C782d1a09faf16eee2bdf365b137c3aae%2C53766bdaf3f63849b506cb5191f961e7%2C40a0c0facfcdad4e0dc618e60ca9e413%2C2622ea890afbebb5521428fc07ba589b%2C15f3489c410bbc3dd881bb4b759acffb%2C5ce0ca293fb953c464dda085f538b782%2C7f927cda8670e1a6f507076d937850ed%2C65a5fed29aae278c485f89232901404c%2Cb47e509fd65154585d8e77ff11f03015%2C51505d09eb905e7248bf0fed77d2816d%2Cec4858f5b660a6df588e03c32f3e735e%2C7da04e3d53d8c5a62541bd5e42fa0672%2C34bf9aeb79753c6e872c0bd58f51c146%2C3daeb348a79430565833d5cd79fba92f%2C4a78403560ef86c4eea1a0b2573203b3%2C43b0ef7d354de97451c4c319cf9db3b5%2C7238ccb9e6c000e224e5454aa784080c%2C311beab01e8c21adb5a026229ecb839d%2C574b903a819d3fa92a1880f6622c9ab5%2C0e06dc3580edf9e4fc3f3dac76e76f71%2Cc02b5c894edff19a96b3422394c04911%2Cf9521e71f41095bc3ccf8021007cb023%2Cbbadaf32ecbe37b60628d0c230dc412f%2Cc7d53014f8da9740eae6afb8513f3ac4%2C709060ead0f67f018416c4fc035e2c3a%2C2b24c444b2c5fe58b1ffaec61f466d00%2C6719949fc8101ddeb59ed1b67512761e%2Cf7ffc9008d90fe6a9a15f796fad2b657%2C3ba8291855c46ebde15bb92a2a633aeb%2Ce75adec1484a3b03c3a79a27a10901e8%2C80b006c1ce5bf675b5590cfbb417abbe%2C47f5bb8284b4015e41c2e7c250d27543%2C35ce7d65b04081847b87b62a81e597b0%2C143a21bafc7707f9373794e1d2d827cf%2C4ec6eddc8d3c20a0b057b6ad8fc67d50%2Cf1159a1c807f13eec2bd7692ab1975b3%2C2059b13e67326286c4398f15782b43bb%2C8571dd34c9eea72bea2fe57c3d60eebc%2C933a3113365e0576c37383fc9f4dd248%2C22fd995384fdb060697414c52cd15b2f%2Cfffd934ee97bdb7d3c2c90ee19e3651c%2Cab27d90bf463cc0a3f264ec7b2ef8578%2Cfe412288e246b9db179a5252d963578a%2C587de9dc60af8a0a804647e9a534a7e0%2C62bf355cb6fa693e7346b9ce036b97a9%2C7adad602a8e6b21bea8b9a8f765a693a%2Cd3c0bd08ee26893f13cbdee1867092da%2Cbe0907ace4d9ca60c8117e11992f1d5a%2C6dd1992ff78e50d024020d02facd8080%2C13cf57a40ad01e563379e776cd04fc37%2Ca21b5f37cd84b6a519f2fc1f8ea28438%2C72d84e1c154562da0ad2655c8ab5234f%2Ca885eeb0ddd95becfd42ee3a7dcaec2b%2Cd57cf3418fa7038113584a393ff6b260%2Cb400d27e54ba06bffd875b6ff73680f8%2C4ed10cf7ef5fb0e73f9c43b2e5e3677a%2C08f16dbb49febf87e541b04407cf2174%2C59534f8c330d4c27d4a8875ba9155748%2Cb1ec86eb9b540dca4654cb9c610ccfa0%2Cbe34bbd1866b0e986ee9bd7107c36a31%2Ccef38aef772342ec503124046ad6a753%2C884d6ae8aafc603f1e8181103ee9b29c%2Cd7ede8e3595c31b88ca9bd673972ed86%2Cbc000578e49ba3a149c8bafa4560974c%2Cf0749ca842cb10ad3c018ce4ec2bcb2f%2C111bc1c0d5b441f0c89e7193ad20d72c%2C6c3fc16410795c0043c51c7203cf5ddf%2C2fc97b3183948688ff4b6b568081b4d9%2Ce28f27c2a1bb6d772b4f46badc754676%2Ca3f9786e1d897b30211ba252f4847209%2C14b2db52dffc5b6d7a936f4fdf8aa3e2%2C67dda89af34162c1a71a71e4275e7e56%2Cab99a810f6723e06e4558b64d41d6498%2Cc40cd16a3a97071d48ce70e644688e29%2C2c512def841aba91d2e9243aadd652ad%2Cc83ad544d048b82d40f977e00157d101&FORMAT=png&MAXEXTENT=29754.890054972%2C-218525.78697617%2C87631.601716573%2C-160649.07531457&GUTTER=0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27492&RANDOM=0.6882094601169229&BBOX=-27150.262730475,-250353.85249421,163349.63439958,-138435.16293029&WIDTH=1440&HEIGHT=846
I get from the command line a bunch of weird characters such as:
8$I*.}(Laà$©¸ô¡0
C¤ÖÒWÀ I*³8$Iê+}cà$©¯ô}0C¤¾Ò÷À8IúJßã8$Iê+}cà$©¯ô}0C¤²ÒÇÀDIúJßã8$Iê+}cà$©¯ô}0C¤¾Ò÷À8I*³8$Iª,}"Ìbà$©²ô0C¤ÖÒWÀ IZK_ 8$I*.}(Laà$©»ô0C¤úÒç@?$IJ_
å
µ}443pH4§ôÝPËÀ!IÒÒw at -$IsJß
µ*}:t2pH4ªôéÐÉÀ!IÒÒw at -$IsJß
ÍÍ)}7Ô2pH4§ôÝPËÀ!IÒÒG at 3$ICJ
Í}443pH4¤ôÑÐÌÀ!IÒÒG at 3$ICJ
*}:t2pH4ôõPÈÀ!IÒÌÒ7@$IcK=
/}L40pH4¿ô=gà$i~é{ ÎÀ!IÒüÒ÷@C¤ù¥ï 8$IÃK
$M.}I0pH4§ôÝPËÀ!IÒ
Ò@9$Iõ¥Ï~IºKß
#ümVoÐMxÒzIEND®B`ngwebsig at websigv5:/usr/lib/cgi-bin$ PuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTYPuTTuTTYPuTTYPuTTYTYP
I checked the folder and the map file is there and is readable. I also tried the same command on a string that has no layers enabled and I get a clean response. I've copied the same project to localhost environment, enabled all the same layers and it worked fine. Could this be something related to the amount of variables passed in the URL ?
2015-12-03 18:42 GMT+00:00 Stephen Woodbridge <woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com>>:
Also, LAYERS=[layergroup] in your url does not look valid.
-Steve
On 12/3/2015 12:35 PM, Donald wrote:
The number of layers of the mapfile is above 250.
I get a error in the console of the browser when the pink screen shows.
It's http://[myIP]/cgi-bin/mapserv?MAP=%2Fvar%2Fwww%2Fhtdocs%2Fwebsig%2Fv5%2Ftmp%2Ftmp%2F0olt4opvnq180qoiaukec1t6o2.map&TRANSPARENT=FALSE&LAYERS=[layergroup]&FORMAT=png&MAXEXTENT=29754.890054972%2C-218525.78697617%2C87631.601716573%2C-160649.07531457&GUTTER=0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27492&RANDOM=0.6198567883111537&BBOX=-36556.702679255,-245546.77592733,153943.1944508,-133628.08636341&WIDTH=1440&HEIGHT=846<http://[myIP]/cgi-bin/mapserv?MAP=%2Fvar%2Fwww%2Fhtdocs%2Fwebsig%2Fv5%2Ftmp%2Ftmp%2F0olt4opvnq180qoiaukec1t6o2.map&TRANSPARENT=FALSE&LAYERS=%5blayergroup%5d&FORMAT=png&MAXEXTENT=29754.890054972%2C-218525.78697617%2C87631.601716573%2C-160649.07531457&GUTTER=0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A27492&RANDOM=0.6198567883111537&BBOX=-36556.702679255,-245546.77592733,153943.1944508,-133628.08636341&WIDTH=1440&HEIGHT=846>
*(net::ERR_EMPTY_RESPONSE) *
The mapfile generated by mapserv exists in the tmp folder and the
structure of the file is right. The map file generated has chmod 777 as
well as the folder. Any help would be appreciated.
2015-12-03 14:35 GMT+00:00 Stephen Woodbridge <woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com>
<mailto:woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com>>>:
Please reply to the list so everyone can benefit from the questions
and answers and there are a lot of other people that might have
input to the problem.
On 12/3/2015 5:35 AM, Donald wrote:
Hi Steve,
I don't believe that it is a problem with open layers. I tested
The point is to load the pink tile in a separate window so you can
view the error message and see why it failed.
individually one layer at a time and I could conclude that I got the
pink screen when a certain amount of activated layers are reached
regardless of the order. Do you know if mapserver has some
configuration
that restrict the number of layers to render or some
configuration about
memory limit to render the layers ?
No, I do not think this is the case. How many layers are in your
mapfile?
-Steve W
thanks
2015-12-02 16:28 GMT+00:00 Stephen Woodbridge
<woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com> <mailto:woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com>>
<mailto:woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com> <mailto:woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com>>>>:
On 12/2/2015 11:22 AM, Donald wrote:
cheers,
I have several layers that I can activate. When I
activate all
at once I get
a pink screen. If I activate a layer individually by
selecting
one at a time
I still get a pink screen even though some layers are
correctly
drawn. I
checked the error log and I the last log line I have says
"freeing map at
0xa022230". To see the map again I have to unselect all
layers.
Any thoughs on how to solve the problem ?
Mostly likely it is only one of some of the layers that are
having
an issue. So trying, selecting one layer at a time to
figure out
which layer is causing the problem.
Also a "pink screen" sounds like you are using OpenLayers
and the
pink is for a failure to render the image. In FireFox,
right click
on the pink image and select view image this image or copy
the image
url and paste it into a new tab/window and you might get an
error
message that would be helpful.
-Steve W
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
<mailto:mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>>
<mailto:mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>>>
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20151204/d9aa672d/attachment-0001.html>
