[mapserver-dev] Trying to improve perfs of MapServer with PostGIS
Patrick Valsecchi
patrick.valsecchi at camptocamp.com
Fri Dec 11 01:13:09 PST 2015
I was a bit disapointed by the perfs of reading the features from PostGIS
compared to reading them from a local Shapefile. So I've pocked my nose
around the code and I saw that geometries were fetched from the DB in EWKB
encoded in hex.
So I went ahead and changed the code to use libpq's binary mode when we are
fetching features. To avoid conversion nightmares when fetching attributes,
I'm tricking Postgres into sending them in their textual form. That way,
the behavior of MapServer should not change regarding the other columns.
The patch can be found in github [1].
General testing algo:
for each zoom level
start at the same time N threads that does
for each iteration
compute random BBOX
get the 1000x1000 image (throw the content out, but read it)
Wait for all the threads to stop
Collect the stats from the threads (throwing out the slowest result and the
fastest result).
The DB is on a db.m4.large from Amazon with SSD disk. Mapserver is on
apache with fcgid (up to 20 processes) and runs on a m4.xlarge. The
measures are taken from another Amazon machine to avoid hitting the
bandwidth limit too fast.
Times are for one query from one thread and are given in milliseconds along
with their standard deviation. Each time, I did a full run before taking
measures.
Data used is the swiss villages (total 2479 features) with polygon contours
in a 1.7MB shapefile file [2], imported as is in PostGIS.
nbThreads=1 nbIterations=20
zoom level 1.00 4.00 16.00 32.00
original 964± 14 222± 126 66± 18 68± 19
binary 807± 13 194± 111 87± 28 79± 24
shapefile 554± 94 187± 107 72± 26 56± 3
nbThreads=5 nbIterations=20
original 3686± 946 403± 264 84± 37 70± 22
binary 1710± 486 340± 242 105± 59 89± 32
shapefile 519± 225 278± 166 91± 58 80± 34
nbThreads=10 nbIterations=20
original 7287±1936 800± 575 119± 79 110± 81
binary 3737± 647 471± 294 123± 70 110± 54
shapefile 884± 241 412± 269 111± 119 98± 57
nbThreads=20 nbIterations=20
original 14969±2507 1643±1221 239± 231 166± 103
binary 7649± 730 857± 576 210± 121 181± 77
shapefile 1455± 438 483± 326 143± 97 126± 75
What is what:
- original: Mapserver 7.0 (git 157fa47)
- binary: Same as above with a small patch to configure libpg to use
binary transfer.
- shapefile: Same as original, but using a shapefile on the local disk
(just here for comparison).
We can see that when the machine gets parallel queries, we quickly get a
factor 2 in perfs when there are a lot of features (low zoom level). There
is no measurable negative impact at higher zoom levels and lower loads.
Now, what do you guys think? Do you see in risk? Or should do a pull
request?
Thanks.
[1]
https://github.com/pvalsecc/mapserver/commit/45bd3d5795c9108618c37cc8c7472809cff54d16
[2]
http://www.swisstopo.admin.ch/internet/swisstopo/en/home/products/landscape/swissBOUNDARIES3D.html
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20151211/2bdbd968/attachment.html>
