[mapserver-dev] Trying to improve perfs of MapServer with PostGIS
Patrick Valsecchi patrick.valsecchi at camptocamp.com
Mon Dec 14 07:10:37 PST 2015
Daniel: I do agree with your analysis.
Even: That is a bit out of scope for this patch and I'm no fan of reducing
the precision, even for WMS.
On Fri, Dec 11, 2015 at 5:06 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le vendredi 11 décembre 2015 13:38:56, Daniel Morissette a écrit :
> > Hi Patrick,
> > We have run into similar behaviors with a quite similar setup on Amazon
> > a little while ago, in our case we had a dedicated DB server with SSD
> > (like yours) and multiple rendering nodes connecting to it, and adding
> > more nodes or more powerful ones still resulted in a constant throughput
> > and the additional rendering nodes CPU running mostly idle. After much
> > hair pulling we finally found out that we were hitting the 1 Gbps limit
> > of the network connection between the DB and rendering node.
> > I suspect you are running into the same thing here: if you could verify
> > that the size of the original vs binary response is about the double,
> > then that would confirm this possibility. We used PGBouncer to look at
> > the volume of data transferred by the DB server, it produces output like
> > this:
> > 2014-06-06 18:49:44.597 27891 LOG Stats: 852 req/s, in 435114 b/s, out
> > 83424883 b/s,query 7133 us
> > 2014-06-06 18:50:44.597 27891 LOG Stats: 818 req/s, in 418046 b/s, out
> > 79177139 b/s,query 5761 us
> > 2014-06-06 18:52:44.598 27891 LOG Stats: 898 req/s, in 458041 b/s, out
> > 88441708 b/s,query 7949 us
> > Then to really confirm it, look at the number of hits per second in each
> > test case (instead of the processing time per request). You will likely
> > notice that it is constant for a given zoom level once you hit the
> > network limit no matter how many parallel requests you have. This is
> > because the number of hits per seconds that can be served are limited by
> > the volume of data per second that the DB server can deliver to
> > MapServer (around ~800Mbits/sec for a 1 Gbps connection).
> > In our case, if I remember correctly, we used to hit a limit of about 40
> > maps/second, where each map was averaging 2MB of data... so we were
> > capping at 4 hits x 2MB ~= 80MBytes per second from the DB (or
> > ~800Mbits/sec) ... which is as I wrote above in line with a 1Gbps limit.
> If bandwidth is the bottleneck, an even more efficient solution than the
> binary
> WKB representation would be to use http://postgis.net/docs/manual-
> dev/ST_AsTWKB.html . This would require a TWKB decoder to be developped in
> MapServer and be likely only appropriate for WMS like scenarios where you
> can
> afford loosing some precision to coordinates values.
> Even
> > Good luck!
> > Daniel
> > On 2015-12-11 4:13 AM, Patrick Valsecchi wrote:
> > > Hi,
> > > I was a bit disapointed by the perfs of reading the features from
> > > PostGIS compared to reading them from a local Shapefile. So I've pocked
> > > my nose around the code and I saw that geometries were fetched from the
> > > DB in EWKB encoded in hex.
> > > So I went ahead and changed the code to use libpq's binary mode when we
> > > are fetching features. To avoid conversion nightmares when fetching
> > > attributes, I'm tricking Postgres into sending them in their textual
> > > form. That way, the behavior of MapServer should not change regarding
> > > the other columns.
> > > The patch can be found in github [1].
> > > General testing algo:
> > > for each zoom level
> > > start at the same time N threads that does
> > > for each iteration
> > > compute random BBOX
> > > get the 1000x1000 image (throw the content out, but read it)
> > > Wait for all the threads to stop
> > > Collect the stats from the threads (throwing out the slowest result and
> > > the fastest result).
> > > The DB is on a db.m4.large from Amazon with SSD disk. Mapserver is on
> > > apache with fcgid (up to 20 processes) and runs on a m4.xlarge. The
> > > measures are taken from another Amazon machine to avoid hitting the
> > > bandwidth limit too fast.
> > > Times are for one query from one thread and are given in milliseconds
> > > along with their standard deviation. Each time, I did a full run before
> > > taking measures.
> > > Data used is the swiss villages (total 2479 features) with polygon
> > > contours in a 1.7MB shapefile file  [2], imported as is in PostGIS.
> > > nbThreads=1 nbIterations=20
> > > zoom level   1.00          4.00          16.00        32.00
> > > original     964±  14      222± 126      66±  18      68±  19
> > > binary       807±  13      194± 111      87±  28      79±  24
> > > shapefile    554±  94      187± 107      72±  26      56±   3
> > > nbThreads=5 nbIterations=20
> > > original    3686± 946      403± 264      84±  37      70±  22
> > > binary      1710± 486      340± 242     105±  59      89±  32
> > > shapefile    519± 225      278± 166      91±  58      80±  34
> > > nbThreads=10 nbIterations=20
> > > original    7287±1936      800± 575     119±  79     110±  81
> > > binary      3737± 647      471± 294     123±  70     110±  54
> > > shapefile    884± 241      412± 269     111± 119      98±  57
> > > nbThreads=20 nbIterations=20
> > > original   14969±2507     1643±1221    239± 231      166± 103
> > > binary      7649± 730      857± 576    210± 121      181±  77
> > > shapefile   1455± 438      483± 326    143±  97      126±  75
> > > What is what:
> > >   * original: Mapserver 7.0 (git 157fa47)
> > >   * binary: Same as above with a small patch to configure libpg to use
> > >     binary transfer.
> > >   * shapefile: Same as original, but using a shapefile on the local
> disk
> > >     (just here for comparison).
> > > We can see that when the machine gets parallel queries, we quickly get
> a
> > > factor 2 in perfs when there are a lot of features (low zoom level).
> > > There is no measurable negative impact at higher zoom levels and lower
> > > loads.
> > > Now, what do you guys think? Do you see in risk? Or should do a pull
> > > request?
> > > Thanks.
> > > [1]
> https://github.com/pvalsecc/mapserver/commit/45bd3d5795c9108618c37cc8c747
> > > 2809cff54d16 [2]
> http://www.swisstopo.admin.ch/internet/swisstopo/en/home/products/landsca
> > > pe/swissBOUNDARIES3D.html
> > > _______________________________________________
> > > mapserver-dev mailing list
> > > mapserver-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20151214/117c28e0/attachment.html>
