[mapserver-dev] Trying to improve perfs of MapServer with PostGIS
Paul Ramsey
pramsey at cleverelephant.ca
Tue Dec 15 10:08:46 PST 2015
TRANSFER_ENCODING was put in when I was testing hex vs base64, and
since I never felt 100% sure about the tradeoff that led to hex
(larger payload, less CPU overhead) I just left it in, in case we ever
wanted to switch back, or in case someone whined about it, so I could
tell them to just change it themselves.
P.
On Mon, Dec 14, 2015 at 10:26 PM, Patrick Valsecchi
<patrick.valsecchi at camptocamp.com> wrote:
> Paul,
> The resultFormat parameter was already there back in 2003 with Postgres 7.4
> when PQexecWithParams was introduced [1]. I hope the current minimum
> supported version of Postgres does not predate that.
> Another question I have before I do a PR: what is the usefulness of all
> those #if TRANSFER_ENCODING? It cannot even be modified through cmake. I'm
> very tempted to remove all that.
> Thanks for your feedback.
> [1]
> http://www.postgresql.org/docs/7.4/static/libpq-exec.html#LIBPQ-EXEC-MAIN
> On Mon, Dec 14, 2015 at 8:15 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Please bear in mind that the original implementation using binary
>> cursors was deliberately *removed* (by me) because it added so much
>> complexity to the code base. (In terms of having to maintain a correct
>> transaction state throughout the query lifecycle.)
>> However, your patch is very small, I see. Perhaps pgsql support of
>> binary has improved a lot since the days of binary cursors. (Which
>> could only be used in transaction, at the time.)
>> Adding TWKB to mapnik has substantially improved network performance [1]
>> for us.
>> http://blog.cartodb.com/smaller-faster/
>> Removing precision in map rendering works like a charm, I'd highly
>> recommend it. However, Mapserver's dual nature as both a feature and
>> map server would make a change to support that more tricky than the
>> Mapnik change.
>> The only issue I'd have to this being a PR is some careful research as
>> to when this RESULTSET_TYPE flag was added to PQexecParams I suppose
>> we could have missed it all those years ago, and thus used binary
>> cursors, but it could also be an add-on as of a certain date. Knowing
>> when it was added would be good. (Probably long enough ago that we
>> don't even need to #ifdef a version test on it, but I would like
>> confirmation.)
>> ATB,
>> P
>> On Mon, Dec 14, 2015 at 7:10 AM, Patrick Valsecchi
>> > Daniel: I do agree with your analysis.
>> > Even: That is a bit out of scope for this patch and I'm no fan of
>> > reducing
>> > the precision, even for WMS.
>> > On Fri, Dec 11, 2015 at 5:06 PM, Even Rouault
>> > <even.rouault at spatialys.com>
>> > wrote:
>> >> Le vendredi 11 décembre 2015 13:38:56, Daniel Morissette a écrit :
>> >> > Hi Patrick,
>> >> > We have run into similar behaviors with a quite similar setup on
>> >> > Amazon
>> >> > a little while ago, in our case we had a dedicated DB server with SSD
>> >> > (like yours) and multiple rendering nodes connecting to it, and
>> >> > adding
>> >> > more nodes or more powerful ones still resulted in a constant
>> >> > throughput
>> >> > and the additional rendering nodes CPU running mostly idle. After
>> >> > much
>> >> > hair pulling we finally found out that we were hitting the 1 Gbps
>> >> > limit
>> >> > of the network connection between the DB and rendering node.
>> >> > I suspect you are running into the same thing here: if you could
>> >> > verify
>> >> > that the size of the original vs binary response is about the double,
>> >> > then that would confirm this possibility. We used PGBouncer to look
>> >> > at
>> >> > the volume of data transferred by the DB server, it produces output
>> >> > like
>> >> > this:
>> >> > 2014-06-06 18:49:44.597 27891 LOG Stats: 852 req/s, in 435114 b/s,
>> >> > out
>> >> > 83424883 b/s,query 7133 us
>> >> > 2014-06-06 18:50:44.597 27891 LOG Stats: 818 req/s, in 418046 b/s,
>> >> > out
>> >> > 79177139 b/s,query 5761 us
>> >> > 2014-06-06 18:52:44.598 27891 LOG Stats: 898 req/s, in 458041 b/s,
>> >> > out
>> >> > 88441708 b/s,query 7949 us
>> >> > Then to really confirm it, look at the number of hits per second in
>> >> > each
>> >> > test case (instead of the processing time per request). You will
>> >> > likely
>> >> > notice that it is constant for a given zoom level once you hit the
>> >> > network limit no matter how many parallel requests you have. This is
>> >> > because the number of hits per seconds that can be served are limited
>> >> > by
>> >> > the volume of data per second that the DB server can deliver to
>> >> > MapServer (around ~800Mbits/sec for a 1 Gbps connection).
>> >> > In our case, if I remember correctly, we used to hit a limit of about
>> >> > 40
>> >> > maps/second, where each map was averaging 2MB of data... so we were
>> >> > capping at 4 hits x 2MB ~= 80MBytes per second from the DB (or
>> >> > ~800Mbits/sec) ... which is as I wrote above in line with a 1Gbps
>> >> > limit.
>> >> If bandwidth is the bottleneck, an even more efficient solution than
>> >> the
>> >> binary
>> >> WKB representation would be to use http://postgis.net/docs/manual-
>> >> dev/ST_AsTWKB.html . This would require a TWKB decoder to be developped
>> >> in
>> >> MapServer and be likely only appropriate for WMS like scenarios where
>> >> you
>> >> can
>> >> afford loosing some precision to coordinates values.
>> >> Even
>> >> > Good luck!
>> >> > Daniel
>> >> > On 2015-12-11 4:13 AM, Patrick Valsecchi wrote:
>> >> > > Hi,
>> >> > > I was a bit disapointed by the perfs of reading the features from
>> >> > > PostGIS compared to reading them from a local Shapefile. So I've
>> >> > > pocked
>> >> > > my nose around the code and I saw that geometries were fetched from
>> >> > > the
>> >> > > DB in EWKB encoded in hex.
>> >> > > So I went ahead and changed the code to use libpq's binary mode
>> >> > > when
>> >> > > we
>> >> > > are fetching features. To avoid conversion nightmares when fetching
>> >> > > attributes, I'm tricking Postgres into sending them in their
>> >> > > textual
>> >> > > form. That way, the behavior of MapServer should not change
>> >> > > regarding
>> >> > > the other columns.
>> >> > > The patch can be found in github [1].
>> >> > > General testing algo:
>> >> > > for each zoom level
>> >> > > start at the same time N threads that does
>> >> > > for each iteration
>> >> > > compute random BBOX
>> >> > > get the 1000x1000 image (throw the content out, but read it)
>> >> > > Wait for all the threads to stop
>> >> > > Collect the stats from the threads (throwing out the slowest result
>> >> > > and
>> >> > > the fastest result).
>> >> > > The DB is on a db.m4.large from Amazon with SSD disk. Mapserver is
>> >> > > on
>> >> > > apache with fcgid (up to 20 processes) and runs on a m4.xlarge. The
>> >> > > measures are taken from another Amazon machine to avoid hitting the
>> >> > > bandwidth limit too fast.
>> >> > > Times are for one query from one thread and are given in
>> >> > > milliseconds
>> >> > > along with their standard deviation. Each time, I did a full run
>> >> > > before
>> >> > > taking measures.
>> >> > > Data used is the swiss villages (total 2479 features) with polygon
>> >> > > contours in a 1.7MB shapefile file [2], imported as is in PostGIS.
>> >> > > nbThreads=1 nbIterations=20
>> >> > > zoom level 1.00 4.00 16.00 32.00
>> >> > > original 964± 14 222± 126 66± 18 68± 19
>> >> > > binary 807± 13 194± 111 87± 28 79± 24
>> >> > > shapefile 554± 94 187± 107 72± 26 56± 3
>> >> > > nbThreads=5 nbIterations=20
>> >> > > original 3686± 946 403± 264 84± 37 70± 22
>> >> > > binary 1710± 486 340± 242 105± 59 89± 32
>> >> > > shapefile 519± 225 278± 166 91± 58 80± 34
>> >> > > nbThreads=10 nbIterations=20
>> >> > > original 7287±1936 800± 575 119± 79 110± 81
>> >> > > binary 3737± 647 471± 294 123± 70 110± 54
>> >> > > shapefile 884± 241 412± 269 111± 119 98± 57
>> >> > > nbThreads=20 nbIterations=20
>> >> > > original 14969±2507 1643±1221 239± 231 166± 103
>> >> > > binary 7649± 730 857± 576 210± 121 181± 77
>> >> > > shapefile 1455± 438 483± 326 143± 97 126± 75
>> >> > > What is what:
>> >> > > * original: Mapserver 7.0 (git 157fa47)
>> >> > > * binary: Same as above with a small patch to configure libpg to
>> >> > > use
>> >> > > binary transfer.
>> >> > > * shapefile: Same as original, but using a shapefile on the local
>> >> > > disk
>> >> > > (just here for comparison).
>> >> > > We can see that when the machine gets parallel queries, we quickly
>> >> > > get
>> >> > > a
>> >> > > factor 2 in perfs when there are a lot of features (low zoom
>> >> > > level).
>> >> > > There is no measurable negative impact at higher zoom levels and
>> >> > > lower
>> >> > > loads.
>> >> > > Now, what do you guys think? Do you see in risk? Or should do a
>> >> > > pull
>> >> > > request?
>> >> > > Thanks.
>> >> > > [1]
>> >> > > https://github.com/pvalsecc/mapserver/commit/45bd3d5795c9108618c37cc8c747
>> >> > > 2809cff54d16 [2]
>> >> > > http://www.swisstopo.admin.ch/internet/swisstopo/en/home/products/landsca
>> >> > > pe/swissBOUNDARIES3D.html
>> >> > > _______________________________________________
>> >> > > mapserver-dev mailing list
>> >> > > mapserver-dev at lists.osgeo.org
>> >> > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> >> Spatialys - Geospatial professional services
>> >> http://www.spatialys.com
