[mapserver-dev] Text editors adding UTF-8 BOM to mapfiles?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jan 6 12:18:59 PST 2015
Hi all,
I have run into a bunch of clients that edit their mapfiles (mostly on
windows) and then get a mapserver error: about the mapfile not starting
with the token MAP.
This is very hard to run down because you can not see these garbage
characters in most editors. Doing a hex dump I get:
00000000 ef bb bf 4d 41 50 0a 20 20 4e 41 4d 45 20 22 4a |...MAP.
NAME "J|
In vim, I just found out that I can:
:set nobomb
:w
And that will remove it. Did I mention that this is really annoying
because it is not obvious what the problem is!
Questions:
1) anyone else run into this?
2) would it be a major security risk to ignore the BOM if it exists?
3) should I open a bug for this?
4) this probably happens on other text files also, but my guess is that
they are less likely to be edited by the client so I'm not seeing it as
a problem.
Thoughts?
-Steve W
