[mapserver-dev] travis-ci msautotest behavior changes
Stephan Meißl stephan at meissl.name
Mon Jul 20 11:09:24 PDT 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Thomas,
thanks for this great addition. I agree that this is only needed in
special cases and leaving the structure with submodules is fine. I don't
recall any specific reasons and don't have a strong opinion though.
cu
Stephan
On 07/20/2015 07:34 PM, thomas bonfort wrote:
> On 20 July 2015 at 17:43, Even Rouault <even.rouault at spatialys.com> wrote:
>> Le lundi 20 juillet 2015 17:20:10, thomas bonfort a écrit :
>>> Hi devs,
>>> The current travis-ci/msautotest setup required us to use a submodule
>>> inside our mapserver git repository, which was somehow a pain to use
>>> as a submodule tracks a specific commit SHA and not a whole branch:
>>> - the submodule's sha needed to be maintained/updated/committed each
>>> time there was a change to the msautotest repository itself
>>> - it was nearly impossible to have travis-ci run using an msautotest
>>> branch from a repo outside of the mapserver organisation, thus making
>>> the creation of pull requests difficult to validate if they required
>>> an update to the autotests themselves.
>>> I've updated the travis test script to now behave like this:
>>> - by default, if there's a commit on mapserver/mapserver 's
>>> branch-7-0, then the autotests from mapserver/msautotest 's branch-7-0
>>> will be used
>>> - you can specify which msautotest repo/version should be used by
>>> specifying it in the commit message, with a line containing (only) the
>>> string msautotest=repo at sha, e.g.
>>> msautotest=git://github.com/mapserver/msautotest.git@master
>>> or
>>> msautotest=git://github.com/tbonfort/msautotest.git@my-feature-branch
>>> or
>>> msautotest=git://github.com/myuser/msautotest.git@a457de23ea
>> Hi Thomas,
>> I agree with your observations on the current situation;
>> How does that work with a pull request made of several commits ? I suppose
>> that only the commit with msautotest= in its message gets tested with the
>> specified msautotest version, and others fallback to head of msautotest's
>> branch-7-.0 ? So consequence is : add msautotest= to all commits of a PR ?
> IIRC, the travis run is only launched on the last commit if you are
> going to push multiple commits in one go. If you're pushing e.g. once
> a day then you'd have to add the msautotest= part on your last commit
> each day. Note that you only need to add that if your branch requires
> a modified version of the autotests.
>> Not sure if there's a developer guide somewhere, but that would be worth
>> adding the above in it.
> I'd added to the wiki already
>> Question: is there a strong reason for not having msautotest has a normal
>> directory of mapserver repo, and docs too ? too big pershaps ? But I'd hope
>> that all developers have mapserver, msautotest and docs checked in, so the
>> size argument doesn't really seem relevant.
>> Personnaly, I'd find it great/simpler to have a single commit with related
>> code, test and doc changes.
> I think the initial idea was to keep the commiter authorizations
> separate. Running/publishing the doc build from travis would also
> prove a bit more difficult if it was on the same repo. What do others
> think?
> Thomas
>> Even
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQIcBAEBAgAGBQJVrTlUAAoJEKNQXeNWi+qtIDgP/R40nCCf+qW2EzvfDPikACJW
Zmh0dyGQ/PAE+ly2NDqvV30qlRxFDJTFGsngDR2Flb2WkDlALHjNQ9JEGYmQRZpf
wXvUGBbSPf3diJtKdlfMqY0Kg+Q+UBuO9wgpwAfcU1Bp5haMnGCC3UOcqtc7YleC
i8ImZ4WYtbwZZoNIFqHGEgBEDAhTXKcUhzMoPb3SyY/LE4P7Wqwg/yAOJdGWNC/i
PDtDKFN80WiYbrjc1dF0X/Lo6WmlldMrwgjyBsk4Hd5saJMQyiA4Do1CNGnJEZIt
tHd3qqRcoQ0MoKhmrZk60p9bga+070swo4M3oYx7e0aSi8D6hqbwr0WgknIPIblN
UhhwxmI+UTg3lBQGCFpA+qpffF24FPyNnhUdBF3zfZdpxuHvLgcZKsiof7q8ah+K
zuFf2vlI+ODSsAiudKrF++gCIq/cuhyeEZsWj7xCXIiAzlBlhkSeiLOKdDr6Xlzs
rNy4vPTl0IFKiQb4H9ToLZwWRFgxPKihtGQYiF3DbI9hFCNiYmuj6hgfAx5RsGEv
sEoNHBpdSegwd55oHRfVH48t28H9LXRMkUvFhh3dZDnQwVbZY0UdKX73eRdVXexT
DUTwrS5BEpWBuqkoQdVwqgSyciC3w8hOk00UF8YD1qmUOi0DRv5ntZ0geGtiADRz
iT+zfTvSsHuLSg8IBr6D
=efM1
-----END PGP SIGNATURE-----
