[mapserver-dev] Adding a time index stamp to returned image.
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Fri Jul 24 14:08:02 PDT 2015
Should be very doable – I like a challenge. You’re not saying much about how you were going about it. I created a quick test that drops the current time in the center of the map where the time is from the now() function in PostgreSQL. See:
http://maps1.dnr.state.mn.us/cgi-bin/mapserv64?mode=map&map=/usr/local/mapserver/apps/test/timestamp/test.map
If you refresh it you’ll get the timestamp associated. Presumably you could format this to your liking using the various utilities in PostgreSQL. To do this I had to create a dummy table in my database that contained a single dummy column, and I added 1 row to it. That allowed me to get useful SQL generated via MapServer. The timestamp layer looks like:
LAYER
NAME “timestamp”
TYPE POINT
STATUS DEFAULT
TRANSFORM FALSE
UNITS PERCENTAGES
CONNECTIONTYPE POSTGIS
CONNECTION “database of your choice”
DATA "the_geom FROM (SELECT ST_MakePoint(.50, .50) AS the_geom, NOW() AS tstamp, dummy_column FROM dummy_table) AS foo USING UNIQUE dummy_column USING SRID=-1"
LABELITEM tstamp
CLASS
LABEL
TYPE TRUETYPE
FONT “verdana-bold”
COLOR 0 0 0
SIZE 12
POSITION CC
END
END
END
To change the location of the point you’d edit the coordinates inside the ST_MakePoint() function. Hope it helps.
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Tuesday, July 21, 2015 4:09 PM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] Adding a time index stamp to returned image.
All,
I’m using a POSTGRES connection an trying to place a timestamp text chunk into the corner of a image from Postgres.
I’ve got a method for generating a set of images for a time-lapse movie (https://www.dropbox.com/s/7spkctc2mmtfmhc/out4.mp4?dl=0), but need to add a timestamp to each of the images upon output. I’m not having much luck though outputting a seemingly simple item from Postgres. Fro some reason TimeStamps are not completely understood by MapServer. Maybe I need to cast the timestamp to a text string or something . . .
Thoughts??
Thanks
bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20150724/02f2dbbd/attachment.html>
