[mapserver-dev] Adding a time index stamp to returned image.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Jul 28 09:24:34 PDT 2015
Hi Jim,
That’s arbitrary for the day of interest. The key point is the “+ INTERVAL %min%” value being added to that base time index. Each day starts at 8:00am and some number of minutes is added to the 8:00am start time to get the next image built.
The begin time (time_idx1) and the number of minutes (min) is passed into the MapFile. I can get back a timestamp as output, but MapServer doesn’t seem to recognize that as a valid data chunk. My next pass at this was going to be to cast the timestamp to text and see if that helps with MapServer being able to use it as a TEXT label.
Steve Lime suggested using a separate layer as well, which might be easier than all this one pass stuff I’m trying to do.
bobb
> On Jul 28, 2015, at 11:12 AM, Jim Klassen <klassen.js at gmail.com> wrote:
> Where does the timestamp literal, '2015-07-21 08:00:00', come from, and
> can't you just use that directly?
> On 07/24/2015 04:30 PM, Basques, Bob (CI-StPaul) wrote:
>> my SQL looks like this:
>> DATA "bbox from (
>> SELECT
>> row_number() over (order by accessed_at nulls last) as seq,
>> client,
>> extract('epoch' from (%time_idx1%::timestamp + INTERVAL '%min% minute' - accessed_at)::interval) as elapsed,
>> id, accessed_at, bbox
>> FROM
>> layer_metrics
>> Where
>> accessed_at < (%time_idx1%::timestamp + INTERVAL '%min% minute')
>> AND
>> accessed_at >= (%time_idx1%::timestamp + INTERVAL '%min% minute' - INTERVAL '10 minute')
>> AND
>> client NOT IN ('%172.17.17.97%','%172.17.17.151%')
>> ) as subquery using unique id using srid=200068"
>> I tried a modified SQL like so:
>> SELECT
>> client,
>> extract('epoch' from ('2015-07-21 08:00:00'::timestamp + INTERVAL '25 minute' - accessed_at)::interval) as elapsed,
>> '2015-07-21 08:00:00'::timestamp + INTERVAL '25 minute' as tstamp,
>> id, accessed_at, to_char(accessed_at - INTERVAL '5 hours', 'HH24:MI:SS') as tstamp --,
>> -- bbox
>> FROM
>> layer_metrics
>> Where
>> accessed_at < ('2015-07-21 08:00:00'::timestamp + INTERVAL '25 minute')
>> AND
>> accessed_at >= ('2015-07-21 08:00:00'::timestamp + INTERVAL '25 minute' - INTERVAL '120 minute')
>> to get the “tstamp" value in all rows:
>> 1;"172.17.16.150";6860;"2015-07-21 08:25:00";2062502;"2015-07-21 06:30:40+00";"01:30:40"
>> 2;"172.17.16.150";6860;"2015-07-21 08:25:00";2062503;"2015-07-21 06:30:40+00";"01:30:40"
>> 3;"172.17.16.150";6860;"2015-07-21 08:25:00";2062504;"2015-07-21 06:30:40+00";"01:30:40"
>> 4;"172.17.16.150";6860;"2015-07-21 08:25:00";2062505;"2015-07-21 06:30:40+00";"01:30:40"
>> 5;"172.17.16.150";6857;"2015-07-21 08:25:00";2062506;"2015-07-21 06:30:43+00";"01:30:43"
>> 6;"172.17.16.150";6857;"2015-07-21 08:25:00";2062507;"2015-07-21 06:30:43+00";"01:30:43"
>> 7;"172.17.16.150";6857;"2015-07-21 08:25:00";2062508;"2015-07-21 06:30:43+00";"01:30:43"
>> 8;"172.17.16.150";6857;"2015-07-21 08:25:00";2062509;"2015-07-21 06:30:43+00";"01:30:43"
>> 9;"172.17.16.150";6842;"2015-07-21 08:25:00";2062510;"2015-07-21 06:30:58+00";"01:30:58"
>> 10;"172.17.16.150";6842;"2015-07-21 08:25:00";2062511;"2015-07-21 06:30:58+00";"01:30:58”
>> Which outputs just peachy, but for some reason a time object won’t come through via an expression for labelling. I think my problem is I’m trying to do it all in one call. I didn’t try a whole separate layer . . .anyway, any of the “tstamp” values will work for the label.
>> bobb
>> On Jul 24, 2015, at 4:08 PM, Lime, Steve D (MNIT) <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>> wrote:
>> Should be very doable – I like a challenge. You’re not saying much about how you were going about it. I created a quick test that drops the current time in the center of the map where the time is from the now() function in PostgreSQL. See:
>> http://maps1.dnr.state.mn.us/cgi-bin/mapserv64?mode=map&map=/usr/local/mapserver/apps/test/timestamp/test.map
>> If you refresh it you’ll get the timestamp associated. Presumably you could format this to your liking using the various utilities in PostgreSQL. To do this I had to create a dummy table in my database that contained a single dummy column, and I added 1 row to it. That allowed me to get useful SQL generated via MapServer. The timestamp layer looks like:
>> LAYER
>> NAME “timestamp”
>> TYPE POINT
>> STATUS DEFAULT
>> TRANSFORM FALSE
>> UNITS PERCENTAGES
>> CONNECTIONTYPE POSTGIS
>> CONNECTION “database of your choice”
>> DATA "the_geom FROM (SELECT ST_MakePoint(.50, .50) AS the_geom, NOW() AS tstamp, dummy_column FROM dummy_table) AS foo USING UNIQUE dummy_column USING SRID=-1"
>> LABELITEM tstamp
>> CLASS
>> LABEL
>> TYPE TRUETYPE
>> FONT “verdana-bold”
>> COLOR 0 0 0
>> SIZE 12
>> POSITION CC
>> END
>> END
>> END
>> To change the location of the point you’d edit the coordinates inside the ST_MakePoint() function. Hope it helps.
>> Steve
>> From: mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
>> Sent: Tuesday, July 21, 2015 4:09 PM
>> To: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
>> Subject: [mapserver-dev] Adding a time index stamp to returned image.
>> All,
>> I’m using a POSTGRES connection an trying to place a timestamp text chunk into the corner of a image from Postgres.
>> I’ve got a method for generating a set of images for a time-lapse movie (https://www.dropbox.com/s/7spkctc2mmtfmhc/out4.mp4?dl=0), but need to add a timestamp to each of the images upon output. I’m not having much luck though outputting a seemingly simple item from Postgres. Fro some reason TimeStamps are not completely understood by MapServer. Maybe I need to cast the timestamp to a text string or something . . .
>> Thoughts??
>> Thanks
>> bobb
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
