[mapserver-dev] Communicating Tile Coordinates Between Mapcache and Mapserver
thomas bonfort
thomas.bonfort at gmail.com
Wed Jun 24 10:35:11 PDT 2015
Mapcache queries the source as a wms getmap request, not as a tiled one.
Remove the 'tile' dimension from your tileset, and the mode=tile and all
the tile*= parameters from your mapcache source URL.
Thomas
On Jun 24, 2015 00:09, "seandisanti" <sdisanti at orionnetworksolutions.com>
wrote:
> I have a page that currently successfully requests tiles from Mapserver
> 6.0.3. The working request looks like:
> "?map=/map/ahps/precip.map&shape_path=2015/06/23/nws_precip_1day_observed_20150623&mode=tile&tilemode=gmap&service=WMS&version=1.1.1&request=GetMap&Styles=default&SRS=EPSG:102100&width=256&height=256&format=image/PNG&TRANSPARENT=TRUE&layers=conus-raster&dpi=120&tile=3+5+4"
> The layer is defined in the map file like:
> LAYER
> NAME 'conus-raster'
> TYPE RASTER
> STATUS DEFAULT
> PROJECTION
> "init=epsg:4326"
> END
> VALIDATION
> "shape_path"
> "^[0-9]{4}\/[0-9]{2}\/[0-9]{2}\/nws_precip_.*_[a-zA-Z]+_[0-9]{8}"
> END
> DATA "/shp/ahps/%shape_path%_conus.png"
> END
> The decision has been made to use mapcache rather than querying mapserver
> directly, and I've set up a source and tileset (I will include below) but I
> am consistently running into errors. I have tried WMS and WMTS services
> because I need to use a dimension to pass the shape_path variable, but if I
> specify tile as a dimension, the regex requires me to treat the pluses in
> the value as spaces, but then it passes the literal string (with pluses) to
> mapserver. Mapserver returns an error that there are the wrong number of
> coordinates, that there should be 3.
> Any help would be greatly appreciated, the only thing stopping me from
> going
> in and modifying the source to split on plus or space is that I wouldn't be
> able to recompile mapserver in our production environment.
> The source in my config file is:
> <source name="precip_conus" type="wms">
> <getmap>
> <params>
> <map>/map/ahps/precip.map</map>
> <version>1.3.0</version>
> <SRS>EPSG:3857</SRS>
> <CRS>EPSG:3857</CRS>
> <SRS>EPSG:102100</SRS>
> <CRS>EPSG:102100</CRS>
> <TRANSPARENT>TRUE</TRANSPARENT>
> <FORMAT>image/png</FORMAT>
> <LAYERS>conus-raster</LAYERS>
> <MODE>TILE</MODE>
> <TILEMODE>gmap</TILEMODE>
> </params>
> </getmap>
> <http>
> <url>url_to_mapserver</url>
> <headers>
> <User-Agent>mod_mapcache/r175</User-Agent>
> <Referrer>url_to_mapcache</Referrer>
> </headers>
> <connection_timeout>10</connection_timeout>
> </http>
> </source>
> and the tileset is:
> <tileset name="precip_conus">
> <source>precip_conus</source>
> <LAYER>conus-raster</LAYER>
> <cache>precip_cache</cache>
> <grid>g2</grid>
> <format>PNG</format>
> <dimensions>
> <dimension type="regex" name="shape_path"
> default="2015/01/01/nws_precip_1day_observed_20150101">^[0-9]{4}\/[0-9]{2}\/[0-9]{2}\/nws_precip_.*_[a-zA-Z]+_[0-9]{8}$</dimension>
> <dimension type="regex" name="tile"
> default="3+5+4">^\d{1,3}\s\d{1,3}\s\d{1,3}$</dimension>
> </dimensions>
> </tileset>
> http://osgeo-org.1560.x6.nabble.com/Communicating-Tile-Coordinates-Between-Mapcache-and-Mapserver-tp5212572.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20150624/9f50eac0/attachment-0001.html>
