[mapserver-dev] Wired behavior of msOWSGetEPSGProj()
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Fri Mar 13 07:21:25 PDT 2015
Ah, thanks Even for the explanation! I missed "static" being a storage class specifier, too. I normally used it only to specify the scope... Maybe it's time to read the C Beginner's Guide once more :(
Thanks a lot!
> -----Ursprüngliche Nachricht-----
> Von: Even Rouault [mailto:even.rouault at spatialys.com]
> Gesendet: Freitag, 13. März 2015 14:48
> An: Eichner, Andreas - SID
> Cc: 'mapserver-dev at lists.osgeo.org'
> Betreff: Re: [mapserver-dev] Wired behavior of msOWSGetEPSGProj()
> Actually, epsgCode is not a stack allocated buffer, but a global one (see
> static keyword), so msOWSGetEPSGProj() is technically correct.
