[mapserver-dev] Upgrading Sphinx/Docs to 1.3.1
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue May 5 14:25:55 PDT 2015
Hi devs,
I notice that our Sphinx installation version (the software that we use
to convert from restructured text to html files automagically) on
mapserver.org is a deprecated 1.1.3 . As noted in our Documentation
Guide[1], our docs process (including the translations) requires a
minimum Sphinx version of 1.2b3
I'm not running Sphinx 1.3.1 locally.
But now how to upgrade the mapserver.org hosted docs to the Sphinx 1.3.1
release, is the challenge.
I have logged into the ProjectsVM and upgraded Sphinx on that machine to
1.3.1 (through the 'easy_install' command) But I haven't seen any
changes to mapserver.org (you can see the Sphinx version listed at the
bottom of every page).
So, question:
Can someone assist me to upgrade Sphinx 1.3.1 on mapserver.org ? I
don't need much of your time, only a few notes on how to upgrade and
then I can run the commands on the server (I will also update the
Documentation Guide with these steps, so people like myself can remember
ha!).
Thanks!
-jeff
[1]
http://www.mapserver.org/development/documentation.html#installing-and-using-sphinx-for-rst-html-generation
