[mapserver-dev] MapScript drawQuery after draw possible?
Martin Kofahl
martin.kofahl at gmail.com
Tue Sep 8 05:00:43 PDT 2015
Hello,
I'm going to port an older MapScript 5 application to the current release
and - probably - getting into trouble with the result cache during draw and
drawQuery. Just to make sure calling drawQuery() right after draw() isn't
utterly wrong, please take a look at the following simplified example.
PREAMBLE:
$map = ms_newMapObj($map_file);
$point = ms_newpointObj();
$point->setXY ...
$layer = $map->getLayerByName ...
$layer->queryByPoint ...
$map->querymap->set('style', MS_SELECTED);
WORKING TEST CASE:
$map->drawQuery();
$map->draw();
FAILING TEST CASE: msPostGISLayerGetShape: Assertion `layer->layerinfo !=
((void *)0)' failed.
$map->draw();
$map->drawQuery();
There are other non-working cases, like processQueryTemplate after draw and
I wonder if draw closes the queried layer somewhat too early.
Thanks for your investigation!
Martin
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20150908/46d6f8cd/attachment.html>
