[mapserver-dev] mapserver/mapscript crash due to _cairo_unscaled_font_fini
Worth Lutz
wal3 at mindspring.com
Thu Apr 21 08:26:56 PDT 2016
Hi Thomas,
I think I got the test case added to the issue,
https://github.com/mapserver/mapserver/issues/5273.
Thanks for looking into this.
*Worth Lutz*
On 04/21/2016 09:24 AM, thomas bonfort wrote:
> Worth,
> I don't think we already have an issue opened for this, so please do
> go and create one. If you can attach a testcase that exhibits the
> problem through a plain shp2img or mapserv call (i.e. not mapscript)
> I'll take a look.
> Regards,
> Thomas
> On 21 April 2016 at 15:13, Worth Lutz <wal3 at mindspring.com
> <mailto:wal3 at mindspring.com>> wrote:
> Hi All,
> I'm seeing a crash, "Aborted (core dumped)" at the end of a cli
> run of mapscript creating some PDF maps.
> I believe this same error happens when calling the same code
> through the web server. That error is shown in the attached
> screenshot from the server.
> My php script has completed it's work and the error occurs during
> the exit of the program. I think during cleanup.
> Google found me these two links which I think describe the same
> problem in Mapnik.
> https://github.com/mapnik/mapnik/issues/3323
> https://github.com/mapnik/mapnik/issues/3304
> I have determined that the problem is related to drawing a layer
> which is putting on labels. I removed the Hwy symbols and just
> left the text and still see the problem. Remove the text and the
> problem goes away.
> I'm running mapServer v6.4.2 on Ubuntu 14.04.
> Is this a known problem? Or do I need to submit a ticket?
> Thanks,
> *Worth Lutz*
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160421/f853479c/attachment.html>
