[mapserver-dev] Typo fixing script in docs
thomas bonfort thomas.bonfort at gmail.com
Tue Feb 2 10:05:02 PST 2016
-1
I see no compelling reason to ask Even to spend more of his time supporting
his script on win32 given that it can be ran offline and/or on a free/libre
VM.
Thank you Even for handling this ingrate task.
Thomas
On Feb 2, 2016 1:49 PM, "Jeff McKenna" <jmckenna at gatewaygeomatics.com>
wrote:
> On 2016-02-02 1:35 PM, Jeff McKenna wrote:
>> On 2016-02-02 12:32 PM, Even Rouault wrote:
>>> Hi,
>>> I've added in a branch ( https://github.com/mapserver/docs/pull/143 ) an
>>> interactive script ./scripts/fix_typos.sh that helps identifying
>>> common typo
>>> fixes, and the fixes it helped finding. This uses the codespell Python
>>> script (
>>> upstream is https://github.com/lucasdemarchi/codespell . Actual
>>> version is my
>>> forked version with a few improvements ) that comes with its own
>>> dictionary.
>>> I've also added the Debian Lintian dictionary and the QGIS dictionary.
>>> The
>>> dictionaries are more code oriented than general purpose I guess, but
>>> there is
>>> a good amount of computerese in our docs, so it is still valuable.
>>> It requires Python 3 (and the first time it is run, git to download
>>> codespell
>>> and curl to download the additional dictionaries)
>>> You can use with : ./scripts/fix_typos.sh
>>> and answering the question when a typo is identified.
>>> A white list of words can be edited in ./scripts/fix_typos.sh itself,
>>> and when
>>> a word is OK only in a specific context, you can add the full line to
>>> whitelist
>>> in scripts/typos_whitelist.txt (sensitive to starting and trailing
>>> whitespace/tabulations, and only work on LF terminated files, hence a
>>> conversion of 2 files from CRLF to LF).
>>> Note: it is only run on en/ files, the dictionaries being only for
>>> English.
>>> Opinions ?
>>> Even
>> Sounds great. When you get to documenting the steps (likely in
>> /development/documentation.txt) be sure to include steps for Windows
>> users as well, as many doc contributors are on Windows.  Also, it would
>> be great to include steps for Python2 users, as I know the MS4W
>> environment was recently upgraded to Python 2.7.11 support. (yes I ask a
>> lot, but, you asked for my opinion :)
>> Thanks!
>> -jeff
> Maybe the answers to both of my questions/requests is to set this up on a
> shared server, and then document the steps to login and run.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160202/de2d4212/attachment-0001.html>
