[mapserver-dev] Streaming output from WCS
Even Rouault even.rouault at spatialys.com
Wed Feb 10 09:48:24 PST 2016
Le mercredi 10 février 2016 18:29:06, Rahkonen Jukka (MML) a écrit :
> Hi,
> Some WCS users would prefer if large output from WCS (large=a few gigabytes
> or more) could be sent streaming with a relatively short lag between the
> request and the start of response. If the output image is made complete on
> the server side before the transfer starts the lag can be some minutes. Is
> it reasonable idea to stream 1-4 GB GeoTIFFs from Mapserver? What
> restrictions would it put to the possible file formats, compression etc?
There are several issues :
- MapServer currently composes a in-memory image of the result, that is
limited to MAXSIZE x MAXSIZE pixels (defaults to 2048 if unspecified). If you
want to generate really big images, then the architecture of the WCS renderer
should be significantly changed. A possibility would perhaps be to use GDAL VRT
to have a on-the-fly result raster, not memory bound.
- if the above is not a problem or solved, you also need an output format with
streaming capabilities. For GeoTIFF, GDAL 2.0 supports creating *uncompressed*
GeoTIFF ( see http://gdal.org/frmt_gtiff.html ). It could likely be extended to
generate compressed GeoTIFF in streaming mode, but I didn't go to that point
as such GeoTIFFs couldn't be read in a streaming way (since the tables with
tiles/strips offsets and sizes must be written at the end of the file, once all
offsets and sizes are known) and the objective was to be able to pipe out /
pipe in the files.
But even if the output format is streamable, MapServer currently either
generates a in-memory or on-disk temporary output file before sending the
bytes. This would require changes in it too.
Even
http://www.spatialys.com
