[mapserver-dev] Motion: Adopt MS RFC 114: Faster retrieval of shape count
Even Rouault even.rouault at spatialys.com
Fri Feb 12 05:17:04 PST 2016
Hi PSC,
I submit this motion to vote:
Adopt MS RFC 114: Faster retrieval of shape count :
http://mapserver.org/development/rfc/ms-rfc-114.html
Following feedback, I've renamed the configuration metadata item, used to
control whether resultType=hits should take into account or ignore
"wfs_maxfeatures", as "wfs_maxfeatures_ignore_for_resulttype_hits".
Whether to default it to true or false depends on how one understands the WFS
spec, so I've let it to the current state of my implementation :
- default to "true" for PostGIS layers, ie the SELECT COUNT(*) is not limited
by the server side limit
- default to "false" for other layers, as currently done.
Best regards,
Even
http://www.spatialys.com
