[mapserver-dev] [mapserver-users] Documentation process: workflow for simple edits
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Fri Feb 19 12:05:15 PST 2016
This is great, will try it myself shortly in a spot where I found "a a". Thanks for the workflow.
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: Wednesday, February 17, 2016 2:02 PM
To: mapserver-dev at lists.osgeo.org; mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Documentation process: workflow for simple edits
Following Jukka's remark about the barrier for entrance for doc improvements,
I've added a "Workflow for simple edits" section for a pure online github-based
workflow that should hopefully make the barrier lower :
http://mapserver.org/development/documentation.html#workflow-for-simple-edits
If it has errors or need improvements, use the above mentionned process to fix
them ;-)
Even
http://www.spatialys.com
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
