[mapserver-dev] Problem with filter in Oracle
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jan 14 05:18:54 PST 2016
Hi Björn,
Thanks for bringing this issue to everyone's attention. Be careful that
most don't know what MapServer versions are associated with MS4W
releases. You can check this through the commandline "mapserv -v" call.
Here is a summary:
- your initial script worked with MapServer 5.0.2 (MS4W 2.2.7)
- script fails with MapServer 6.0.3 (MS4W 3.0.6) and MapServer 7.0 (MS4W
3.1.1)
-jeff
On 2016-01-14 5:30 AM, Björn Danielsson wrote:
> Hi,
> I have been using ms4w for quite some time and have discovered problems
> with Oracle when using php_mapscript. I posted this problem at ms4w's
> support and was adviced to turn to you.
> I am supporting a gis-system on the web that is heavily database
> dependent, and can run on either postgres or oracle according to the
> costumer's request. So there are two sets of php-scripts that are
> identical apart from the database calls.
> Thera are no problems with postgres.
> With Oracle there is a funny problem with filter.
> Look at this:
> foreach($aLayersIdx as $layerIndex) {
> $oLayerK = $oMapK->getLayer($layerIndex);
> if ($bDebug) {
> fwrite($f,"layer: ".$oLayerK->name."\r\n");
> if ($oLayerK->name == "AVD" && $avd == "") {
> $oLayerK->set("status",MS_OFF);
> continue;
> $filter = "";
> switch ($oLayerK->name) {
> case "AVD" :
> $filter = "([ORGID]='".$orgid."' AND [FV]='".$fv."' AND
> [BEV]='".$bev."' AND [SKIFTE]='".$skifte."' AND [AVD]='".$avd."')";
> $data = "KARTOBJ_SDO FROM ".$dbowner.".AVD*AVD";
> break;
> case "X" :
> $filter = "([ID]='".$sessid."')";
> $data = "KARTOBJ_SDO FROM ".$dbowner.".KARTA*TMP2";
> break;
> $data = str_replace("*","$",$data);
> $oLayerK->set("data", $data);
> $oLayerK->setFilter($filter);
> $oLayerK->setConnectionType(MS_ORACLESPATIAL);
> $oLayerK->set("connection", $conn);
> $oLayerK->set("status", MS_ON);
> if ($bDebug) {
> fwrite($f,"connection: ".$conn."\r\n");
> fwrite($f,"filter: ".$filter."\r\n");
> fwrite($f,"data: ".$data."\r\n");
> A mapfile with two layers, 'AVD' and 'X'.
> Problem is that filter for layer 'X' does not work. Or, rather, it works
> but no record is returned. The mapserver debugger reports no error.
> The filter for layer 'AVD' works fine.
> When the line $filter = "[ID]='".$sessid."')" is commented and the table
> KARTA$TMP2 contains only one record it works and a map layer is
> produced. So it seems that when filter is introduced in the select
> something goes wrong.
> I thought that ID might be a reserved word but after some testing I
> found that filter fails in calls to other tables as well.
> For example:
> This works
> [BEV]='".$bev."')";
> But this does not work
> [BEV]='".$bev."' AND [SKIFTE]='".$skifte."')";
> The problem is consistent in that way that where the problem occurs it
> always occurs, and where it not occurs it never occurs. It is not
> intermittent.
> The php script ( where the snippet came from above ) was developed under
> ms4w version 2.2.7 and at that time no problems occured. I have also
> used version 3.0.6 and 3.1.1 and both versions have problems. So
> somewhere between 2.2.7 and 3.0.6 something happened.
> I am at loss here.
> Björn Danielsson
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
